メインコンテンツまでスキップ
If you missed the pre-registration for NetApp MS Azure AD B2C Go Live, when you log in, the new login prompt will offer the option to register. Please note that access to your NetApp data may take up to 1 hour. Need assistance? Complete this form and select “Registration Issue” as the Feedback Category.
ブリッジの検出が原因で Active IQ Unified Manager MetroCluster の監視が失敗します
14
Visibility:
Votes:
0
Category:
active-iq-unified-manager
Specialty:
om
Last Updated:
環境
  • アクティブ IQ Unified Manager 9.7
  • ストレッチ MetroCluster システム
問題
1 つ以上の MetroCluster クラスタで障害が頻繁に発生しており、監視ステータスが「失敗」のままになっている。
エラーが発生しました au.log
INFO  [oncommand] [collection-completion-0] [c.n.d.i.m.MccFabricConfigDiscoveryHandler] MetroCluster discovery started for clustername
ERROR [oncommand] [collection-completion-0] [c.n.d.i.m.MccFabricConfigDiscoveryHandler] MetroCluster monitoring failed for clustername
エラーが発生しました ocumserver.log
2020-04-07 08:16:17,963 ERROR [oncommand] [reconcile-3] [trtnas02mp(incremental@08:16:15.965)] [c.n.dfm.collector.OcieJmsListener] Inventory change listener error
com.netapp.dfm.ontap.outbound.zapi.OcumMonitoringFailedException: could not execute batch
Caused by: org.hibernate.exception.ConstraintViolationException: could not execute batch...
Caused by: java.sql.BatchUpdateException: (conn=673) Duplicate entry '16069-2131000011' for key 'nodebridgeconnection.NodeBridgeConnection_NodeId_BridgeId_UQ'...
Caused by: java.sql.SQLIntegrityConstraintViolationException: (conn=673) Duplicate entry '16069-2131000011' for key 'nodebridgeconnection.NodeBridgeConnection_NodeId_BridgeId_UQ'
Caused by: java.sql.SQLException: Duplicate entry '16069-2131000011' for key 'nodebridgeconnection.NodeBridgeConnection_NodeId_BridgeId_UQ'
に続けてを押します
org.springframework.dao.DataIntegrityViolationException: could not execute batch; SQL [insert into NodeBridgeConnection (resourceKey, objVersion, objectName, healthStatus, bridge_id, cluster_id, node_id, id) values (?, ?, ?, ?, ?, ?, ?, ?)]; constraint [nodebridgeconnection.PRIMARY]; nested exception is org.hibernate.exception.ConstraintViolationException: could not execute batch
メモ:Unified Manager ログファイルの場所
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
