OCI Health ページで異常検出エンジンが報告される:「 Error: failing to monitor job(s) 」
環境
- OnCommand Insight ( OCI ) 7.3.8+ 以降
- 異常検出エンジン( ADE )
問題
- OCI Health ページで異常検出エンジンが報告される:
"ERROR: Failing to monitor job(s)"
prelet.log
次の出力がにある場合があります<install_drive>Program Files\SANscreen\wildfly\standalone\log
2020-04-07 09:03:09,572 ERROR PrelertRetryUtil - Failure of attempt 1 of request of type FLUSH_ML_JOB following delay of 0 milliseconds. Request will be tried again after delay of 0 milliseconds.
java.util.concurrent.ExecutionException: org.apache.http.ConnectionClosedException: Connection closed
[truncated]
2020-04-07 09:03:09,614 ERROR PrelertRetryUtil - Failure of attempt 2 of request of type FLUSH_ML_JOB following delay of 0 milliseconds. Request will be tried again after delay of 4000 milliseconds.
java.util.concurrent.ExecutionException: java.net.ConnectException: Connection refused
[truncated]
2020-04-07 09:03:44,578 ERROR PrelertClient - Failed to add data to Anomaly Detection Engine for <job_name>. Http status response: HTTP/1.1 409 Conflict.
- ADE CLI からの次のコマンドの出力では、少なくとも 1 つの失敗したジョブが報告されます。
curl -X GET "localhost:9200/_xpack/ml/anomaly_detectors/_stats?pretty"
[truncated]
"state" : "failed",
"assignment_explanation" : ""
[truncated]
