メインコンテンツまでスキップ
Coming soon...New Support-Specific categorization of Knowledge Articles in the NetApp Knowledge Base site to improve navigation, searchability and your self-service journey.
OnCommand Insight がパフォーマンスアーカイブをリストアできませんでした
20
Visibility:
Votes:
0
Category:
oncommand-insight
Specialty:
oci
Last Updated:
に適用されます
  • OnCommand Insight 7.3.9 ( OCI )
  • Windows
問題
  • OCI Web インターフェイスの Admin > Troubleshooting > Load Performance Archive で、次のエラーが表示されます。 ,  the following error is seen:
PerformanceArchiverBean (http://PerformanceArchiverBean.java:956) - Failed to load archive for date: >>Wed Jan 22 18:22:44 CET 2020<<. Error: Error restoring performance data
  • archiverer.log ファイルに次のエラーが表示されます。
2020-04-21 20:24:47,688 ERROR [default task-37710] ElasticCommon (ElasticCommon.java:538) - Exception while restoring snapshot
com.netapp.oci.es.ElasticsearchException: Exception while restoring snapshot
Caused by: java.util.concurrent.ExecutionException: RemoteTransportException[[SESKWPRDOCI01][127.0.0.1:9310][cluster:admin/snapshot/restore]]; nested: IndexNotFoundException[no such index];
   at org.elasticsearch.common.util.concurrent.BaseFuture$Sync.getValue(BaseFuture.java:265) ~[elasticsearch.jar!/:6.8.3]
   at org.elasticsearch.common.util.concurrent.BaseFuture$Sync.get(BaseFuture.java:252) ~[elasticsearch.jar!/:6.8.3]
   at org.elasticsearch.common.util.concurrent.BaseFuture.get(BaseFuture.java:94) ~[elasticsearch.jar!/:6.8.3]
   at com.netapp.oci.es.admin.ElasticAdminManager.restoreSnapshot(ElasticAdminManager.java:587) ~[elasticsearch-client.jar!/:?]
   ... 219 more
Caused by: com.netapp.oci.es.utils.ExceptionSurrogate: [org.elasticsearch.transport.RemoteTransportException] [SESKWPRDOCI01][127.0.0.1:9310][cluster:admin/snapshot/restore]
Caused by: com.netapp.oci.es.utils.ExceptionSurrogate: [org.elasticsearch.index.IndexNotFoundException] no such index
archiver.log:このファイルは、 %SANscreen \WildFly\standalone\log ディレクトリにあります
New to NetApp?
Scan to view the article on your device
  • この記事は役に立ちましたか?
