メインコンテンツまでスキップ
elasticsearch の oci-cluster.log で ' 開いているファイルが多すぎます ' というエラーが発生しました
4
Visibility:
Votes:
0
Category:
oncommand-insight
Specialty:
oci
Last Updated:
に適用されます
  • OnCommand Insight 7.3.
  • Red Hat Enterprise Linux(RHEL)
問題
OnCommand Insight Web GUI が応答しないか、または完全にロードされていません。
elasticsearch の oci-cluster.log に ' 開いているファイルが多すぎます ' というエラーが含まれています。次の例を参照してください。
      [DEBUG][o.e.a.a.i.s.TransportIndicesStatsA ction] [xxx.xxx.local] [indices:monitor/stats] failed to execute operation for shard [[oci-inventory-qtree-2018-04-02-12-48][1], node[gtIfs6jjQdmsxx5Ji4Uo7g], [P], s[STARTED], a[id=2YH5gjjRQk-ooHjtZr3uhg]]
      org.elasticsearch.ElasticsearchException: failed to refresh store stats
       at org.elasticsearch.index.store.Store$StoreStatsCache.refresh(Store.java:1393) ~[elasticsearch-5.6.3.jar:5.6.3]
       at org.elasticsearch.index.store.Store$StoreStatsCache.refresh(Store.java:1378) ~[elasticsearch-5.6.3.jar:5.6.3]
       at org.elasticsearch.common.util.SingleObjectCache.getOrRefresh(SingleObjectCache.java:54) ~[elasticsearch-5.6.3.jar:5.6.3]
       at org.elasticsearch.index.store.Store.stats(Store.java:332) ~[elasticsearch-5.6.3.jar:5.6.3]
       at org.elasticsearch.index.shard.IndexShard.storeStats(IndexShard.java:703) ~[elasticsearch-5.6.3.jar:5.6.3]
       at org.elasticsearch.action.admin.indices.stats.CommonStats.<init>(CommonStats.java:177) ~[elasticsearch-5.6.3.jar:5.6.3]
       at org.elasticsearch.action.admin.indices.stats.TransportIndicesStatsAction.shardOperation(TransportIndicesStatsAction.java:163) ~[elasticsearch-5.6.3.jar:5.6.3]
       at org.elasticsearch.action.admin.indices.stats.TransportIndicesStatsAction.shardOperation(TransportIndicesStatsAction.java:47) ~[elasticsearch-5.6.3.jar:5.6.3]
       at org.elasticsearch.action.support.broadcast.node.TransportBroadcastByNodeAction$BroadcastByNodeTransportRequestHandler.onShardOperati on(TransportBroadcastByNodeAction.java:433) [elasticsearch-5.6.3.jar:5.6.3]
       at org.elasticsearch.action.support.broadcast.node.TransportBroadcastByNodeAction$BroadcastByNodeTransportRequestHandler.messageReceive d(TransportBroadcastByNodeAction.java:412) [elasticsearch-5.6.3.jar:5.6.3]
       at org.elasticsearch.action.support.broadcast.node.TransportBroadcastByNodeAction$BroadcastByNodeTransportRequestHandler.messageReceive d(TransportBroadcastByNodeAction.java:399) [elasticsearch-5.6.3.jar:5.6.3]
       at org.elasticsearch.transport.TransportRequestHandler.messageReceived(TransportRequestHandler.java:33) [elasticsearch-5.6.3.jar:5.6.3]
       at org.elasticsearch.transport.RequestHandlerRegistry.processMessageReceived(RequestHandlerRegistry.java:69) [elasticsearch-5.6.3.jar:5.6.3]
       at org.elasticsearch.transport.TransportService$7.doRun(TransportService.java:644) [elasticsearch-5.6.3.jar:5.6.3]
       at org.elasticsearch.common.util.concurrent.ThreadContext$ContextPreservingAbstractRunnable.doRun(ThreadContext.java:638) [elasticsearch-5.6.3.jar:5.6.3]
       at org.elasticsearch.common.util.concurrent.AbstractRunnable.run(AbstractRunnable.java:37) [elasticsearch-5.6.3.jar:5.6.3]
       at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_162]
       at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_162]
       at java.lang.Thread.run(Thread.java:748) [?:1.8.0_162]
      Caused by: java.nio.file.FileSystemException: /var/lib/netapp/oci/elasticsearch/nodes/0/indices/tKE39cPAR5CG88PIDruJRg/1/index: Too many open files
       at sun.nio.fs.UnixException.translateToIOException(UnixException.java:91) ~[?:?]
       at sun.nio.fs.UnixException.rethrowAsIOException(UnixException.java:102) ~[?:?]
       at sun.nio.fs.UnixException.rethrowAsIOException(UnixException.java:107) ~[?:?]
       at sun.nio.fs.UnixFileSystemProvider.newDirectoryStream(UnixFileSystemProvider.java:427) ~[?:?]
       at java.nio.file.Files.newDirectoryStream(Files.java:457) ~[?:1.8.0_162]
       at org.apache.lucene.store.FSDirectory.listAll(FSDirectory.java:215) ~[lucene-core-6.6.1.jar:6.6.1 9aa465a89b64ff2dabe7b4d50c472de32c298683 - varunthacker - 2017-08-29 21:54:39]
       at org.apache.lucene.store.FSDirectory.listAll(FSDirectory.java:234) ~[lucene-core-6.6.1.jar:6.6.1 9aa465a89b64ff2dabe7b4d50c472de32c298683 - varunthacker - 2017-08-29 21:54:39]
       at org.apache.lucene.store.FilterDirectory.listAll(FilterDirectory.java:57) ~[lucene-core-6.6.1.jar:6.6.1 9aa465a89b64ff2dabe7b4d50c472de32c298683 - varunthacker - 2017-08-29 21:54:39]
       at org.elasticsearch.index.store.Store$StoreStatsCache.estimateSize(Store.java:1399) ~[elasticsearch-5.6.3.jar:5.6.3]
       at org.elasticsearch.index.store.Store$StoreStatsCache.refresh(Store.java:1391) ~[elasticsearch-5.6.3.jar:5.6.3]
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
