メインコンテンツまでスキップ
HDS データソースのパフォーマンス収集が OCI で断続的に失敗します
17
Visibility:
Votes:
0
Category:
oncommand-insight
Specialty:
om
Last Updated:
に適用されます
  • OnCommand Insight 7.3.9 ( OCI )
  • HDS データソース
問題
  • HDS データソースのパフォーマンス収集が OCI で失敗し、で検出されたエラーなどが報告されます acq.log
2020-07-31 19:37:21,440 ERROR [DSM-pool-3-thread-39698] com.onaro.sanscreen.acquisition.framework.datasource.BaseDataSource (AggregatedDataSourceErrorsException.java:142) -     Error 1 out of 1: HDS [External process run timed out] - External command timed out after 240 seconds: "D:\Program Files\SANscreen\java64\bin\java" -classpath "c:\export\lib\JSanExportLoader.jar" -Xmx512m -Dmd.command=D:\Program Files\SANscreen\acq\log\runtime\HDS\storageperformance_1596213179591\recording_hdsexpcmd_xxx.xxx.xxx.56.txt -Dmd.logpath=D:\Program Files\SANscreen\acq\log\runtime\HDS\storageperformance_1596213179591\recording_2020_07_31_19_32_59_623_expOutDir_xxx.xxx.xxx56 sanproject.getexptool.RJElMain ([Device name 443317]: External command timed out after 240 seconds: "D:\Program Files\SANscreen\java64\bin\java" -classpath "c:\export\lib\JSanExportLoader.jar" -Xmx512m -Dmd.command=D:\Program Files\SANscreen\acq\log\runtime\HDS\storageperformance_1596213179591\recording_hdsexpcmd_xxx.xxx.xxx.56.txt -Dmd.logpath=D:\Program Files\SANscreen\acq\log\runtime\HDS\storageperformance_1596213179591\recording_2020_07_31_19_32_59_623_expOutDir_xxx.xxx.xxx56 sanproject.getexptool.RJElMain)
com.onaro.sanscreen.acquisition.process.error.ProcessTimeoutException: External command timed out after 120 seconds: "D:\Program Files\SANscreen\java64\bin\java" -classpath "c:\export\lib\JSanExportLoader.jar" -Xmx512m -Dmd.command=D:\Program Files\SANscreen\acq\log\runtime\HDS\storageperformance_1596213179591\recording_hdsexpcmd_xxx.xxx.xxx.56.txt -Dmd.logpath=D:\Program Files\SANscreen\acq\log\runtime\HDS\storageperformance_1596213179591\recording_2020_07_31_19_32_59_623_expOutDir_xxx.xxx.xxx56 sanproject.getexptool.RJElMain
   at com.onaro.sanscreen.acquisition.process.AcqProcessManager$AcqProcessRunner.call(AcqProcessManager.java:405) ~[hds_hicommand.jar:?]
   at com.onaro.sanscreen.acquisition.process.AcqProcessManager$AcqProcessRunner.call(AcqProcessManager.java:223) ~[hds_hicommand.jar:?]
   at java.util.concurrent.FutureTask.run(FutureTask.java:266) [?:1.8.0_231]
   at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_231]
   at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_231]
   at java.lang.Thread.run(Thread.java:748) [?:1.8.0_231]
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
