メインコンテンツまでスキップ
OCI のインストールエラー: MySQL を起動できません
6
Visibility:
Votes:
0
Category:
oncommand-insight
Specialty:
oci
Last Updated:
に適用されます
OnCommand Insight ( OCI ) AKA SANscreen の略
問題
OCI のインストールサーバに障害が発生した
入力  SANscreen\bin\log\install.mysql.log:
Checking for listener at localhost:3306
waitfor: timeout
[ant] Exiting C:\Program Files (x86)\SANscreen\bin\server.xml.
BUILD FAILED
C:\Program Files (x86)\SANscreen\bin\setup.xml:175: The following error occurred while executing this line:
C:\Program Files (x86)\SANscreen\bin\server.xml:81: Failed to start mysql
at org.apache.tools.ant.ProjectHelper.addLocationToBuildException(ProjectHelper.java:541)
at org.apache.tools.ant.taskdefs.Ant.execute(Ant.java:418)
at org.apache.tools.ant.UnknownElement.execute(UnknownElement.java:288)
at sun.reflect.GeneratedMethodAccessor2.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:597)
at org.apache.tools.ant.dispatch.DispatchUtils.execute(DispatchUtils.java:105)
at org.apache.tools.ant.Task.perform(Task.java:348)
at org.apache.tools.ant.Target.execute(Target.java:357)
at org.apache.tools.ant.Target.performTasks(Target.java:385)
at org.apache.tools.ant.Project.executeSortedTargets(Project.java:1329)
at org.apache.tools.ant.Project.executeTarget(Project.java:1298)
at org.apache.tools.ant.helper.DefaultExecutor.executeTargets(DefaultExecutor.java:41)
at org.apache.tools.ant.Project.executeTargets(Project.java:1181)
at org.apache.tools.ant.Main.runBuild(Main.java:698)
at org.apache.tools.ant.Main.startAnt(Main.java:199)
at org.apache.tools.ant.launch.Launcher.run(Launcher.java:257)
at org.apache.tools.ant.launch.Launcher.main(Launcher.java:104)
Caused by: C:\Program Files (x86)\SANscreen\bin\server.xml:81: Failed to start mysql
at org.apache.tools.ant.taskdefs.Exit.execute(Exit.java:142)
at org.apache.tools.ant.helper.SingleCheckExecutor.executeTargets(SingleCheckExecutor.java:38)
at org.apache.tools.ant.taskdefs.Ant.execute(Ant.java:416)
... 16 more
--- Nested Exception ---
Total time: 10 minutes 7 seconds
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
