メインコンテンツまでスキップ
OnCommand Insight がパフォーマンスアーカイブをリストアできませんでした
16
Visibility:
Votes:
0
Category:
oncommand-insight
Specialty:
oci
Last Updated:
に適用されます
  • OnCommand Insight 7.3.9 ( OCI )
  • Windows
問題
  • OCI Web インターフェイスの Admin > Troubleshooting > Load Performance Archive で、次のエラーが表示されます。 ,  the following error is seen:
PerformanceArchiverBean (http://PerformanceArchiverBean.java:956) - Failed to load archive for date: >>Wed Jan 22 18:22:44 CET 2020<<. Error: Error restoring performance data
  • archiverer.log ファイルに次のエラーが表示されます。
2020-04-21 20:24:47,688 ERROR [default task-37710] ElasticCommon (ElasticCommon.java:538) - Exception while restoring snapshot
com.netapp.oci.es.ElasticsearchException: Exception while restoring snapshot
Caused by: java.util.concurrent.ExecutionException: RemoteTransportException[[SESKWPRDOCI01][127.0.0.1:9310][cluster:admin/snapshot/restore]]; nested: IndexNotFoundException[no such index];
   at org.elasticsearch.common.util.concurrent.BaseFuture$Sync.getValue(BaseFuture.java:265) ~[elasticsearch.jar!/:6.8.3]
   at org.elasticsearch.common.util.concurrent.BaseFuture$Sync.get(BaseFuture.java:252) ~[elasticsearch.jar!/:6.8.3]
   at org.elasticsearch.common.util.concurrent.BaseFuture.get(BaseFuture.java:94) ~[elasticsearch.jar!/:6.8.3]
   at com.netapp.oci.es.admin.ElasticAdminManager.restoreSnapshot(ElasticAdminManager.java:587) ~[elasticsearch-client.jar!/:?]
   ... 219 more
Caused by: com.netapp.oci.es.utils.ExceptionSurrogate: [org.elasticsearch.transport.RemoteTransportException] [SESKWPRDOCI01][127.0.0.1:9310][cluster:admin/snapshot/restore]
Caused by: com.netapp.oci.es.utils.ExceptionSurrogate: [org.elasticsearch.index.IndexNotFoundException] no such index
archiver.log:このファイルは、 %SANscreen \WildFly\standalone\log ディレクトリにあります
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
