SnapDrive for UNIX で、エラーが発生してストレージが表示されません。表示するネットアップデバイスがありません
環境
SnapDrive for UNIX
問題
SnapDrive for Unix コマンドを実行すると
snapdrive storage list -all
エラーが返されますWARNING: This operation can take several minutes based on the configuration.
0001-185 Command error: storage show failed: no NETAPP devices to show or add the host to the trusted hosts (options trusted.hosts) and enable SSL on the storage system or retry
after changing snapdrive.conf to use http for storage system communication and restarting SnapDrive daemon.
sd-trace.log.init: から入手できます
07-10-2021 17:40:41 [55834 bfb77740]i,2,17,Filer::getIpAddressByDns: ntapstorage1 => 192.168.0.130
07-10-2021 17:40:41 [55834 bfb77740]v,2,6,Operation::getMgmtInterfaceFromDatapath: get_sysmgmt_from_datapath: 192.168.0.130 ret: 33
07-10-2021 17:40:41 [55834 bfb77740]v,2,6,Operation::getMgmtInterfaceFromDatapath: datapath:ntapstorage1 sysName:NULL mgmtInterface:ntapstorage1 isConfigured:0
07-10-2021 17:40:41 [55834 bfb77740]v,2,6,Operation::getMgmtpathFromSysname: get_mgmtpath_from_sysname: ret: 33
07-10-2021 17:40:41 [55834 bfb77740]v,2,6,Operation::getMgmtpathFromSysname: sysName:ntapstorage1 mgmtpath:ntapstorage1 isConfigured:0
07-10-2021 17:40:41 [55834 bfb77740]v,2,18,FilerZephyr::connect: filername:ntapstorage1 mgmtInterface:ntapstorage1
07-10-2021 17:40:41 [55834 bfb77740]i,2,18,FilerZephyr::output in =
