メインコンテンツまでスキップ
We are redesigning the NetApp Knowledge Base site to make it easier to use and navigate. The new and improved site will be available the first week of October. Check out our video or read this KB article to know more about changes you’ll see on the site.
NDB バックアップが断続的に失敗し、「 Volume "xxxx" does not exist in Vserver "xxxx" 」というエラーが表示されます。理由:エントリが存在しません
21
Visibility:
Votes:
0
Category:
netapp-data-broker
Specialty:
snapx
Last Updated:
に適用されます
NetApp Data Broker ( NDB ) 1.0/1.0.1
問題
  • NDB バックアップ中に、何らかの理由で API 障害が発生した場合、 API を再試行すると間違った SVM 名が指定されます。
  • これにより、エラーが発生します。Volume "xxxx" does not exist in Vserver "xxxx". Reason: entry doesn't exist.
たとえば、ボリュームVolume_A""SVM_ASVM_Bは "" に存在しますが、 API を再試行すると誤って "" と指定されています。
YYYY-MM-DD HH:MM:SS.XXX +09:00 [ERR] API exception
YYYY-MM-DD HH:MM:SS.XXX +09:00 [ERR] Failed to run a command New-NcSnapshotMulti
YYYY-MM-DD HH:MM:SS.XXX +09:00 [DBG] ex.InnerException.InnerException.Message : An error occurred while sending the request. Unable to read data from the transport connection: Broken pipe.
YYYY-MM-DD HH:MM:SS.XXX +09:00 [DBG] ex.InnerException.Message : Volume "Volume_A" does not exist in Vserver "SVM_B". Reason: entry doesn't exist.
YYYY-MM-DD HH:MM:SS.XXX +09:00 [DBG] No retry condition match found or max retry reached. Throwing error Volume "Volume_A" does not exist in Vserver "SVM_B". Reason: entry doesn't exist.
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
