メインコンテンツまでスキップ
We are redesigning the NetApp Knowledge Base site to make it easier to use and navigate. The new and improved site will be available the first week of October. Check out our video or read this KB article to know more about changes you’ll see on the site.
CVO では 16 を超える CPU が認識されない
8
Visibility:
Votes:
0
Category:
cloud-volumes-ontap-cvo
Specialty:
core
Last Updated:
環境
  • NetApp Cloud Volumes ONTAP ( CVO )
  • ONTAP 9.7
問題
64 CPU のインスタンスを使用して CVO をセットアップすると、認識される CPU は最大 16 個です。
例:
m5.16xlarge( AWS )インスタンスを使用
m5.16xlarge"" には 64 個の CPU があります。
::> node run -node cluster1-01 -command sysconfig -a
   NetApp Release 9.7P7: Thu Aug 27 16:59:02 EDT 2020
   System ID: XXXXXXXXX (clouster1-01); partner ID: XXXXXXXX (cluster1-02)
   System Serial Number: XXXXXXXX (Cluster1-01)
   System Storage Configuration: Unknown
   System ACP Connectivity: NA
   All-Flash Optimized: false
   Capacity Optimized: false
   All SAN Array: false
   slot 0: System Board 2.5 GHz (Virtual Machine)
         Model Name:      CDvM200
         Serial Number:    XXXXXXXXX
         Loader version:    1.0
         Processors:     16   <--- 16 Processors
         Processor ID:     0xXXXXXXX
         Microcode Version:  0xXXXXXXX
         Memory Size:     259156 MB
         Memory Attributes:  None
         Virtual NVRAM Size: 2048 MB
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
  • この記事は役に立ちましたか?
