メインコンテンツまでスキップ
Exciting new changes are coming to the Knowledge Base site soon!
Starting April 4, 2023, you will notice Support-Specific categorization and improvements to the search filters on the site. In May, we will be launching a new and enhanced Site UI and Navigation. To know more, read our Knowledge Article.
BES-53248 ファームウェアを 3.4.4.4 からダウングレードできません
22
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
hw
Last Updated:
に適用されます
  • BES-53248
  • ファームウェアのダウングレード
  • ファームウェアバージョン 3.4.4.4
問題
BES-53248 ファームウェアを 3.4.4.4 からダウングレードすると、次のエラーが発生して失敗します。
bes-switch) #copy <file_path_url> active
Mode........................................... HTTP
Set Server IP.................................. <server_ip>
Path........................................... ./
Filename....................................... EFOS-<destination_version>.stk
Data Type...................................... Code
Destination Filename........................... active
Management access will be blocked for the duration of the transfer
Are you sure you want to start? (y/n) y
File transfer in progress. Management access will be blocked for the duration of the transfer. Please wait...
HTTP Code transfer starting...
File transfer operation failed.
New to NetApp?
Scan to view the article on your device
