メインコンテンツまでスキップ
Exciting new changes are coming to the Knowledge Base site soon!
Starting April 4, 2023, you will notice Support-Specific categorization and improvements to the search filters on the site. In May, we will be launching a new and enhanced Site UI and Navigation. To know more, read our Knowledge Article.
SSL を確立しようとすると、 HA ペアは reset フラグを送信します 接続
18
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
core
Last Updated:
に適用されます
  • ONTAP 9
問題
  • 新しく追加したノードへの https アクセスは許可されていません
  • AutoSupport Apache ログには次の情報が記録されます
[ssl:notice] [pid 8553:tid 34385512448] [client xx.xx.xx.xx:38526] [vserver 4294967295] No server certificate chain is configured for this vserver
[ssl:notice] [pid 8553:tid 34385512448] [client xx.xx.xx.xx:38526] [vserver 4294967295] Certificate-based client authentication is not configured for this vserver
[ssl:emerg] [pid 8553:tid 34385512448] AH02562: Failed to configure certificate 127.0.0.1:0 (with chain), check /mroot/etc/vserver_4294967295/certificates/ssl/server/<cert_serial_number>/server.crt
[ssl:emerg] [pid 8553:tid 34385512448] SSL Library Error: error:02001002:system library:fopen:No such file or directory (fopen('/mroot/etc/vserver_4294967295/certificates/ssl/server/<cert_serial_number>/server.crt','r'))
New to NetApp?
Scan to view the article on your device
