メインコンテンツまでスキップ
ONTAP S3サーバへのHTTPS接続が「Connection was closed before we received a valid response from endpoint URL」と表示されて失敗する
441
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
core<a>2009163015</a>
Last Updated:
環境
  • ONTAP S3
  • SSL証明書
問題
  • を使用してONTAP S3サーバに接続しようとすると awscli、接続に失敗し、次のメッセージが表示されます。
Connection was closed before we received a valid response from endpoint URL: "https://s3_svm.example.com/".
  • CURL出力:
# curl -I https://s3_svm.example.com -v
* About to connect() to s3_svm.example.com port 443 (#0)
*   Trying 192.168.0.1...
* Connected to s3_svm.example.com (192.168.0.1) port 443 (#0)
* Initializing NSS with certpath: sql:/etc/pki/nssdb
*   CAfile: /etc/pki/tls/certs/ca-bundle.crt
  CApath: none
* NSS error -5978 (PR_NOT_CONNECTED_ERROR)
* Network file descriptor is not connected
* Closing connection 0
curl: (35) Network file descriptor is not connected
  • OpenSSLクライアント出力:
# openssl s_client -connect s3_svm.example.com:443 -tls1_2 -status -msg -debug -showcerts -tlsextdebug -prexit -state
CONNECTED(00000003)
SSL_connect:before/connect initialization
>>> ??? [length 0005]
   16 03 01 01 25
write to 0x7f9580 [0x8030b3] (298 bytes => 298 (0x12A))
>>> TLS 1.2 Handshake [length 0125], ClientHello
SSL_connect:SSLv3 write client hello A
read from 0x7f9580 [0x7feb63] (5 bytes => -1 (0xFFFFFFFFFFFFFFFF))
SSL_connect:error in SSLv3 read server hello A
write:errno=104
no peer certificate available
No client certificate CA names sent
SSL handshake has read 0 bytes and written 0 bytes
New to NetApp?
