メインコンテンツまでスキップ
NetApp Response to Russia-Ukraine Cyber Threat
In response to the recent rise in cyber threat due to the Russian-Ukraine crisis, NetApp is actively monitoring the global security intelligence and updating our cybersecurity measures. We follow U.S. Federal Government guidance and remain on high alert. Customers are encouraged to monitor the Cybersecurity and Infrastructure Security (CISA) website for new information as it develops and remain on high alert.
クラスタ CLI を使用したサービスプロセッサのファームウェアアップグレードでシステムパニックが発生する
4
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
core
Last Updated:
のしんだ
環境
  • サービスプロセッサ SP
  • ONTAP 9
問題
  • クラスタ CLI を使用 wafl.inconsistent.dirent したサービスプロセッサファームウェアのアップグレードでアラートがトリガーされ、ノードがパニック状態になります。
  • 同様 EMS のエントリがログに表示されます。
Mon Dec 20 14:13:31 CET [NODE02: wafl_exempt01: wafl.inconsistent.dirent:EMERGENCY]: ERROR: BUG in matching parameters () to definition params: {'name': 'SP_FW.zip', 'vol': 'vol0', 'app': '', 'volident': '', 'dfh4': '-872398136', 'dfh0': '0', 'dfh2': '19292', 'dfh3': '44867963', 'func': 'wafl_nfs_lookup', 'dfh1': '0', 'owner': '', 'fh4': '-872398136', 'ino_type': '', 'fh1': '0', 'fh0': '0', 'fh3': '323401497', 'fh2': '25704'}
Mon Dec 20 14:13:31 CET [NODE02: wafl_exempt01: callhome.wafl.inconsistent:alert]: Call home for WAFL INCONSISTENT
Mon Dec 20 14:13:31 CET [NODE02: wafl_exempt01: wafl.inconsistent.vol:error]: WAFL inconsistent: volume vol0 is inconsistent. Note: Any new Snapshot copies might contain this inconsistency.
Mon Dec 20 14:13:32 CET [NODE02: wafl_exempt00: wafl.inconsistent.vol:error]: WAFL inconsistent: volume vol0 is inconsistent. Note: Any new Snapshot copies might contain this inconsistency.
Mon Dec 20 14:13:32 CET [NODE02: wafl_exempt03: sk.panic:alert]: Panic String: prod/common/wafl/nfsops.c:10588: Assertion failure. in SK process wafl_exempt03 on release 9.3P6 (C)
Scan to view the article on your device
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
