ストレージプールがデグレード状態で表示されています
- 14
- Visibility:
- Public
- Votes:
- 0
- Category:
- ontap-9
- Specialty:
- core<a>2008786113</a><a>翻訳用</a>
- Last Updated:
環境
ONTAP 9.6P6
問題
ストレージプールがデグレードと表示される。
Cluster::> storage pool show SP1 -instance
Storage
Pool Name: SP1
UUID of Storage Pool: xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx
Nodes Sharing the Storage Pool: Node01, Node02
Number of Disks in Storage Pool: 23
Allocation Unit Size: 5.02TB
Allocation Unit Data Size for RAID4:
4.80TB
Allocation Unit Data Size for RAID-DP: 4.58TB
Allocation Unit Data Size for RAID-TEC: 4.36TB
Storage Type: SSD
Storage Pool
Usable Size: 0B
Storage Pool Total Size: 20.08TB
Is Pool Healthy?: false
State of the Storage Pool:degraded
Reason for Storage
Pool Being Unhealthy:Storage pool has more number of disks than expected.
