メインコンテンツまでスキップ
NetApp wins prestigious Coveo Relevance Pinnacle Award. Learn more!
INSIGHT Japan :2023年 1月25日(水)ANAインターコンチネンタルホテル開催 へ参加・申込を行う
選択:仮想マシンに無効な CPU 割り当てが要求されました
424
Visibility:
Votes:
0
Category:
ontap-select
Specialty:
core
Last Updated:
に適用されます
  • ONTAP Select
  • ESXi
問題
選択したノード / クラスタの導入がCPU admission check failedエラーにより失敗しました:
NodeStartErr: Node "node01" failed to start: (Cannot 'start' VM node01: SOAP Fault:                   -----------                                                     Fault string: The amount of CPU resource available in the parent resource pool is insufficient for the operation. Module 'MonitorLoop' power on failed. Group vm.74195: Cannot admit virtual machine: CPU admission check failed. Invalid reservation 8380 mhz. Group host/user: Invalid CPU allocation requested for virtual machine vmm0:node01. (min: 8380 mhz, max: -1, minLimit: -1, shares: -3) Could not power on virtual machine: Admission check failed for cpu resource. See the VMware ESX Resource Management Guide for information on resource management settings. Failed to power on VM. Failed to start the virtual machine. An error was received from the ESX host while powering on VM node01. Fault detail: ).
New to NetApp?
Scan to view the article on your device
