「 chassis power degraded : Power Supply Status Critical 」という警告メッセージが表示されます
に適用されます
FAS8060
問題
に、次のメッセージを示します EMS-LOG-FILE.GZ
Jan 03 05:47:28 JST [node_name: sp_config_main: spmgmt.driver.timeout:warning]: The software driver for the Service Processor (SP) detected a problem: Unable to update SP network information at this time.
Jan 03 05:50:31 JST [node_name: env_mgr: monitor.chassisPowerSupply.degraded:notice]: Chassis power supply 1 is degraded: PSU1 Temperature is Critical Low (0 C)
Jan 03 05:50:31 JST [node_name: env_mgr: monitor.chassisPowerSupply.degraded:notice]: Chassis power supply 1 is degraded: PSU1 Fan1 Speed is Critical Low (2100 RPM)
Jan 03 05:50:31 JST [node_name: env_mgr: monitor.chassisPowerSupply.degraded:notice]: Chassis power supply 1 is degraded: PSU1 Fan2 Speed is Critical Low (0 RPM)
Jan 03 05:50:34 JST [node_name: power_low_monitor: monitor.chassisPower.degraded:warning]: Chassis power is degraded: Power Supply Status Critical.
Jan 03 05:50:34 JST [node_name: power_low_monitor: callhome.chassis.power:error]: Call home for CHASSIS POWER DEGRADED: Power Supply Status Critical.
PSU1 TempPSU1 Fan Speed でも、では正常です ENVIRONMENT
Sensor Name State Current Critical Warning Warning Critical
Reading Low Low High High
PSU1 need replacement NO
PSU1 State GOOD
PSU1 Temp normal 17 C 0 C 5 C 50 C 60 C
PSU1 Fan1 Speed normal 10700 RPM 4500 RPM 4600 RPM -- --
PSU1 Fan2 Speed normal 9600 RPM 4500 RPM 4600 RPM -- --
