メインコンテンツまでスキップ
シャーシの温度が高すぎます。 CPU0 Temp Margin is critical high(0 C) 」というアラートが表示されます
20
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
に適用されます
  • FAS8200
  • サービスプロセッサ( SP )ファームウェア 5.7 以前
問題
  • CPU0 の場合は重大な高温が報告されますが、読み取り値は 0 です。
Thu Apr 09 02:29:55 BST [node_name: env_mgr: monitor.chassisTemperature.warm:alert]: Chassis temperature is too warm: CPU0 Temp Margin is critical high (0 C).
Thu Apr 09 02:30:00 BST [node_name: monitor: monitor.globalStatus.critical:EMERGENCY]: Chassis temperature is too high..
Thu Apr 09 02:30:55 BST [node_name: env_mgr: callhome.chassis.hitemp:error]: Call home for CHASSIS OVER TEMPERATURE
Wed Apr 15 13:36:58 BST [node_name: env_mgr: monitor.chassisTemperature.warm:alert]: Chassis temperature is too warm: CPU0 Temp Margin is critical high (0 C).
Wed Apr 15 13:37:42 BST [node_name: env_mgr: callhome.chassis.hitemp:error]: Call home for CHASSIS OVER TEMPERATURE
  • 環境プラットフォームセンサーの出力は次のとおりです。
Chassis Thermal Zone discrete fault  normal OVER_TEMP
Temp Average High  discrete fault  normal YES
CPU0 Temp Avg   thermal  crit-high 0 C
CPU0 Temp Margin  thermal  crit-high 0 C
Is Board Over Temp  discrete fault  normal OVER_TEMP
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
