「Invalid chassis configuration(incompatible partner PCM)」というメッセージが表示される
環境
- ONTAP 9
- サービス プロセッサ(SP)
- Baseboard Management Controller(BMC)
問題
- SP / BMCのリセットによってシステムがパニック状態になる可能性があります。
- SPログには次のメッセージが表示されます。
Apr 13 07:42:16 2021 [SP.critical]: Rebooting SP due to loss of ACP comms
Jan 1 00:00:40 1970 [IPMI.notice]: 7b03 | c0 | OEM: ffff70005100 | ManufId: 150300 | SP Reset Internally
Jan 1 00:00:50 1970 [IPMI.notice]: 7c03 | 02 | EVT: 0301ffff | Power_Good | Assertion Event, "State Asserted"
Jan 1 00:00:50 1970 [IPMI.notice]: 7d03 | 02 | EVT: 0301ffff | Power_Proc_OK | Assertion Event, "State Asserted"
Jan 1 00:00:50 1970 [IPMI.notice]: 7e03 | 02 | EVT: 0301ffff | Controller_Fault | Assertion Event, "State Asserted"
Jan 1 00:00:51 1970 [IPMI.notice]: 7f03 | 02 | EVT: 0900ffff | LkWrench_Port_Up | Assertion Event, "Device Disabled"
Jan 1 00:01:02 1970 [SP.notice]: Running primary version 2.10
Jan 1 00:01:05 1970 [SP.normal]: Heartbeat started
Jan 1 00:01:05 1970 [Heartbeat.notice]: Heartbeat start: Set SP time. Old time: Thu Jan 1 00:01:05 1970. New time: Tue Apr 13 07:44:06 2021.
Apr 13 07:44:06 2021 [Heartbeat.notice]: Heartbeat time adjusted: Set SP time. Old time: Thu Jan 1 00:01:05 1970. New time: Tue Apr 13 07:44:06 2021.
Apr 13 07:44:06 2021 [IPMI.notice]: 8003 | 02 | EVT: 6fc22fff | System_FW_Status | Assertion Event, "OnTap Kernel Running"
Apr 13 07:44:06 2021 [IPMI.notice]: 8103 | 02 | EVT: 0300ffff | Controller_Fault | Assertion Event, "State Deasserted"
Apr 13 07:45:09 2021 [IPMI.warning]: FRUID 1 Access error
Apr 13 07:45:30 2021 [ASUP.notice]: First notification email | (INVALID CHASSIS CONFIGURATION (Incompatible Partner PCM)) CRITICAL | Sent
Apr 13 08:00:12 2021 [ASUP.notice]: Reminder email | (INVALID CHASSIS CONFIGURATION (Incompatible Partner PCM)) CRITICAL | Sent
