メインコンテンツまでスキップ
Coming soon...New Support-Specific categorization of Knowledge Articles in the NetApp Knowledge Base site to improve navigation, searchability and your self-service journey.
HAペアを転用する際に「No local disks found error」というエラーが発生します
5
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
core
Last Updated:
環境
  • ONTAP 9
  • ストレージ
  • FASシステム
  • AFFシステム
問題
  • 初期化された2つのノードはブートできません。
  • Clean configuration and initialize all disksのエラーは、オプションを続行しようとしたときに発生します。
例:
 * Press Ctrl-C for Boot Menu. *
 Attempting to use existing varfs on /dev/nvrd1
 No SVM keys found.
 Boot Menu will be available.
 Firewall rules loaded.
 Battery charge capacity: xxxx mA*hr. Power outage protection flash de-staging cycles: xx
 Please choose one of the following:
 (1) Normal Boot.
 (2) Boot without /etc/rc.
 (3) Change password.
 (4) Clean configuration and initialize all disks.
 (5) Maintenance mode boot.
 (6) Update flash from backup config.
 (7) Install new software first.
 (8) Reboot node.
 Selection (1-8)? 4
fm_run0: no local disks found & OFW channel is not up.
WARNING: 0 disks found!
[localhost:cf.fm.noMBDisksOrIc:error]: Could not find the local mailbox disks. Could not determine the firmware state of the partner through the HA interconnect.
WARNING: there do not appear to be any disks attached to the system.
No root volume found.
Rebooting... (press ctrl-c during boot to break reboot loop)
  • disk show -v 保守モードでコマンドを実行して、ディスクが発行されたノードに割り当てられているかどうかを確認します。
例:
*> disk show -v
Local System ID: 537093362
  DISK    OWNER     POOL  SERIAL NUMBER  HOME      DR HOME    CHKSUM
0b.00.11   Not Owned   NONE  S396NA0HC11111  Block
0b.00.0   Not Owned   NONE  S396NA0HC11111  Block
0b.00.8   Not Owned   NONE  S396NA0HC11111  Block
0b.00.10   Not Owned   NONE  S396NA0J111111  Block
0b.00.3   Not Owned   NONE  S396NA0HC11111  Block
0b.00.4   Not Owned   NONE  S396NA0HC11111  Block
0b.00.6   Not Owned   NONE  S396NA0J111111  Block
0b.00.1   Not Owned   NONE  S396NA0HC11111  Block
0b.00.7   Not Owned   NONE  S396NA0HC11111  Block
0b.00.9   Not Owned   NONE  S396NA0HC11111  Block
0b.00.2   Not Owned   NONE  S396NA0HC11111  Block
0b.00.5   Not Owned   NONE  S396NA0J111111  Block
New to NetApp?
Scan to view the article on your device
