メインコンテンツまでスキップ
「 2 つのインターコネクトリンクのいずれかに障害が発生しました」というトラップアラートを検出しました
37
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
環境
  • FAS8080
  • ONTAP 9
問題
  • EMS log ノード 1 のノードとノード 2 の間のインターコネクトポート ib0a ポートが停止し、ただちにリストアされます。
[?] Sun May 23 13:06:00 JST [node 1: mlx4_intr_handler: ic.linkStatusChange:info]: HA interconnect: Port ib0a link is down.
[?] Sun May 23 13:06:00 JST [node 1: ctrl_hb_port_ib0a: ctrl.rdma.heartBeat:info]: HA interconnect: Missed heartbeat to XXX.XXX.XXX.XXX.
[?] Sun May 23 13:06:01 JST [node 1: monitor: monitor.globalStatus.nonCritical:error]: One of the two interconnect links has failed.
[?] Sun May 23 13:06:06 JST [node 1: mlx4_intr_handler: ic.linkStatusChange:info]: HA interconnect: Port ib0a link is up.
  • sysconfig -a リンクステータスがアクティブであると表示されます。
NetApp Release 9.1P16: Wed Nov 14 00:22:10 EST 2018
 System ID: 0537090755 (node 1); partner ID: 0537090720 (node 2)
 System Serial Number: 451713000103 (node 1)
 System Rev: C3
 Interconnect Port 1:
  Port Name:   ib0a
  Default GID:     XXXX:0000:0000:0000:00a0:9800:0035:XXXX
  Base LID:       0x3c
  Active MTU:      4096
  Data Rate:      40 Gb/s (4X) QDR
  Link State:     ACTIVE
  QSFP Vendor:     Molex Inc.
  QSFP Part Number:   112-00374 A0
  QSFP Type:      Active Optical 5m ID:00
  QSFP Serial Number: XXXXXXXXXXXXXX
 Interconnect Port 2:
  Port Name:   ib0b
  Base LID:       0x3d
  Active MTU:      4096
  Link State:     ACTIVE
Scan to view the article on your device
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
