"MONITOR.SHUTDOWN緊急事態電源がオフになっているクラスタでBattery not presentアラート」メッセージが表示される
- 132
- Visibility:
- Public
- Votes:
- 0
- Category:
- fas-systems<a>NVMEM バッテリ </a><a />
- Specialty:
- hw
- Last Updated:
環境
- FAS2520
- FAS2750
- FAS2650
- FAS9000
- BMC ファームウェア11.4
- SP 4.5P1
- SP 2.2.2x5
問題
- ノードの電源がしばらくオフになりました。
- これらの ノードに対してコンソールにアラートがトリガーされるようになりました。
WARNING: The battery is unfit to retain data during a power
outage. This is likely because the battery is
discharged but could be due to other temporary
conditions.
When the battery is ready, the boot process will
complete and services will be engaged.
To override this delay, press 'c' followed by 'Enter'
Jun 22 14:13:46 [node_name:callhome.battery.failure:EMERGENCY]: Call home for BATTERY (not present) CRITICAL.
Jun 22 14:14:47 [node_name:nvmem.battery.notPresent:ALERT]: The NVMEM battery is not present. To prevent data loss, the system will shut down in 5 minutes.
- BMCイベント:
Record 340: Wed May 20 11:43:44.630000 2020 [BMC.critical]: Heartbeat stopped
Record 341: Tue May 26 11:34:28.490000 2020 [IPMI.emergency]: env_mgr triggers OS halt:Battery not charging
Record 342: Mon Jun 01 15:48:26.930000 2020 [IPMI.emergency]: env_mgr triggers OS halt:Battery not charging
Record 343: Tue Jun 02 11:39:47.920000 2020 [IPMI.notice]: 0041 | 02 | EVT: 0301ffff | PSU2_Fault | Assertion Event, "State Asserted"
Record 344: Tue Jun 02 11:39:51.950000 2020 [IPMI.notice]: 0042 | 02 | EVT: 0300ffff | PSU2_Fault | Assertion Event, "State Deasserted"
Record 345: Sun Jun 07 07:56:18.290000 2020 [IPMI.notice]: 0043 | 02 | EVT: 01500505 | Bat_Dstg_Cycles | Assertion Event, "Lower Non-critical going low " | Reading: 5.000 | Threshold: 5.000
Record 346: Mon Jun 08 19:33:49.610000 2020 [IPMI.notice]: 0044 | 02 | EVT: 01520202 | Bat_Dstg_Cycles | Assertion Event, "Lower Critical going low " | Reading: 2.000 | Threshold: 2.000
Record 347: Tue Jun 09 21:52:05.280000 2020 [IPMI.emergency]: env_mgr triggers OS halt:Battery remain capaci
Record 348: Thu Jun 11 02:09:09.540000 2020 [IPMI.emergency]: env_mgr triggers OS halt:Battery not charging
Record 349: Sat Jun 13 14:21:57.820000 2020 [IPMI.emergency]: env_mgr triggers OS halt:Battery not charging
Record 350: Sat Jun 13 19:13:59.160000 2020 [IPMI.emergency]: env_mgr triggers OS halt:Battery not charging
Record 351: Sat Jun 13 19:42:53.140000 2020 [IPMI.notice]: 0045 | 02 | EVT: 01503838 | Bat_Volt | Assertion Event, "Lower Non-critical going low " | Reading: 5.600 | Threshold: 5.600
Record 352: Sat Jun 13 20:11:23.670000 2020 [IPMI.notice]: 0046 | 02 | EVT: 01523737 | Bat_Volt | Assertion Event, "Lower Critical going low " | Reading: 5.500 | Threshold: 5.500
Record 353: Sat Jun 13 20:17:23.700000 2020 [IPMI.emergency]: env_mgr triggers OS halt:Battery voltage criti
Record 354: Sat Jun 13 22:11:21.710000 2020 [IPMI.emergency]: env_mgr triggers OS halt:Battery not charging
Record 355: Sun Jun 14 00:07:34.270000 2020 [IPMI.notice]: 0047 | 02 | EVT: 0301ffff | Bat_Power_Fault | Assertion Event, "State Asserted"
Record 356: Sun Jun 14 00:15:34.300000 2020 [IPMI.emergency]: env_mgr triggers OS halt:Battery not present
Record 402: Mon Jun 22 11:43:49.530000 2020 [IPMI.emergency]: env_mgr triggers OS halt:Battery not present
Record 403: Mon Jun 22 11:53:49.880000 2020 [IPMI.emergency]: env_mgr: FailSafe Power Off
Record 404: Mon Jun 22 11:53:49.890000 2020 [IPMI Event.critical]: System power down
Record 427: Mon Jun 22 12:01:30.780000 2020 [IPMI.emergency]: env_mgr triggers OS halt:Battery not present
Record 538: Mon Jun 22 14:19:46.300000 2020 [IPMI.emergency]: env_mgr triggers OS halt:Battery not present
