メインコンテンツまでスキップ
A400でシャーシのファンFRUに障害が発生しました
3
Visibility:
Votes:
0
Category:
fas-systems<a>2009392369</a>
Specialty:
hw
Last Updated:
環境
  • AFF-A400
  • FAS8300
  • C400
問題
  • EMSで次のエラーが報告される
Dec 06 17:27:00 [node02:monitor.globalStatus.critical:EMERGENCY]: There are no enough spare disks. Assign unowned disks. One fan has failed: SysFan4 F2.
Dec 06 17:33:00 [node02:monitor.globalStatus.critical:EMERGENCY]: There are no enough spare disks.  One fan has failed: SysFan4 F2.
Wed Dec 07 13:31:38 +0900 [node02: notifyd: asup.post.drop:error]: AutoSupport message (HA Group Notification from iscsi-vc054-swn-02 (CHASSIS FAN FRU FAILED: Fan4_2) ERROR) was not posted to NetApp. The system will drop the message.
  • 一方または両方のファンのセンサーステータスはです "BAD"
SysFan4 F1    discrete    normal          normal    GOOD
SysFan4 F2    discrete    fault          normal    BAD
New to NetApp?
