メインコンテンツまでスキップ
シャーシの電源装置がデグレード状態になっています。PSUファン速度がクリティカルローです
31
Visibility:
Votes:
0
Category:
fas-systems<a>2008659152.</a>
Specialty:
hw
Last Updated:
環境
  • 電源装置( PSU )
  • FASシステム
  • AFFシステム
問題
  • EMS レポートではChassis power supply is degraded: PSU Fan Speed is Critical Low、と報告されます。
[Node1:monitor.chassisPowerSupply.degraded:notice]: Chassis power supply 1 is degraded: PSU1 has failed
[Node1:monitor.chassisPowerSupply.degraded:notice]: Chassis power supply 1 is degraded: PSU1 DC has failed
[Node1:callhome.chassis.ps.degraded:error]: Call home for CHASSIS POWER SUPPLY DEGRADED: PS 1
[Node1:monitor.chassisPowerSupply.degraded:notice]: Chassis power supply 1 is degraded: PSU1 Fan1 Speed is Critical Low (2600 RPM)
  • environment status に、影響を受けるPSUの条件を示します。
PSU1 Fault                               FAULT
PSU1 DC OK                               FAULT
PSU1 ON                                     ON
PSU1 Input OK                               OK
PSU1 Fan2 Fault                             OK
PSU1 Fan2 Speed          normal          7500 RPM    4500 RPM    4600 RPM      --          --
PSU1 Fan1 Fault                             OK
PSU1 Fan1 Speed         critlow         2800 RPM    4500 RPM    4600 RPM      --          --
PSU1 Curr                normal          3790 mA       --          --          --          --
PSU1 Temp                normal            25 C         0 C         5 C        50 C        60 C
Scan to view the article on your device
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
