メインコンテンツまでスキップ
NetApp wins prestigious Coveo Relevance Pinnacle Award. Learn more!
INSIGHT Japan :2023年 1月25日(水)ANAインターコンチネンタルホテル開催 へ参加・申込を行う
FAS2650 パニックリブート
124
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
hw
Last Updated:
に適用されます
FAS2650
問題
FS2650 はパニック状態で再起動します。
PANIC : PCI Error NMI from device(s):RPT(0,1,0):PLX PCIE 8725 switch on Controller.
version: 9.3: Thu Jan 4 03:00:09 PST 2018
conf : x86_64.optimize
cpuid = 3
Uptime: 1064d21h2m38s
fpudna: fpcurthread == curthread
PANIC: PCI Error NMI from device(s):RPT(0,1,0):PLX PCIE 8725 switch on Controller. in process idle: cpu3 on release 9.3 (C) on Tue Feb 9 17:01:40 JST 2021
compile flags: x86_64.optimize
HA: current time (in sk_msecs) 92005240804 (in sk_cycles) 174404934374763539
DUMPCORE: START
Dumping to disks: 0b.00.23P1
DUMPCORE: END -- coredump written
coredump: compression ms 39164 compressions 12624 bytes in 34107015168 bytes out 8665915679 ratio 393%
comp BW 830MB/s
coredump: write ms 50496 write count 2258 write bytes 8666017792 write BW 163MB/s
coredump: total ms 150138 chunks of all zeroes 383
System rebooting...
sysconfig -a に ERRORMOD が表示されている Flash Cache NVMe ファームウェアバージョンです
slot 1: Flash Cache NVMe
Serial Number: XXXXXXXXXXXXXX
Part Number: XXX-XXXXX
Hardware Revision: A0
Firmware Version: ERRORMOD
Model Name: X3310A
Capacity: 512 GB
Vendor Name: Samsung
State: ok
New to NetApp?
Scan to view the article on your device
