メインコンテンツまでスキップ
NetApp wins prestigious Coveo Relevance Pinnacle Award. Learn more!
INSIGHT Japan :2023年 1月25日(水)ANAインターコンチネンタルホテル開催 へ参加・申込を行う
FAS3250 のテイクオーバーは非同期ログで無効になります
19
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
に適用されます
  • FAS3250
  • Data ONTAP 8.1.4P1
問題
  • メッセージログに次のエラーメッセージが表示されます。
例:
Sun Oct 11 12:26:28 KST [node4:cf.fsm.takeoverOfPartnerDisabled:notice]: Failover monitor: takeover of node3 disabled (unsynchronized log).
Sun Oct 11 12:26:33 KST [node4:cf.fsm.takeoverOfPartnerEnabled:notice]: Failover monitor: takeover of node3 enabled
Sun Oct 11 12:28:09 KST [node4:cf.ic.xferTimedOut:error]: raid interconnect transfer timed out
Sun Oct 11 12:28:10 KST [node4:cf.fsm.takeoverOfPartnerDisabled:notice]: Failover monitor: takeover of node3 disabled (unsynchronized log).
Sun Oct 11 12:29:51 KST [node4:cf.ic.xferTimedOut:error]: raid interconnect transfer timed out
Sun Oct 11 12:29:56 KST [node4:cf.fsm.takeoverOfPartnerEnabled:notice]: Failover monitor: takeover of node3 enabled
Sun Oct 11 12:33:14 KST [node4:cf.ic.xferTimedOut:error]: raid interconnect transfer timed out
Sun Oct 11 12:33:20 KST [node4:cf.fsm.takeoverOfPartnerEnabled:notice]: Failover monitor: takeover of node3 enabled
  • cf statusを参照してください
例:
node4*> cf status
node3 is up.
node4 has disabled takeover by node3 (unsynchronized log)
RDMA Interconnect is up (Link 0 up, Link 1 up).
node3*> cf status
node4 is up, node4 disabled because of reason (unsynchronized log)
New to NetApp?
Scan to view the article on your device
