理由コード 0x9 およびが表示された FCP アダプタレポート "scsitarget.hwpfct.mserr" エラー および EMS の応答コード 0x8001
に適用されます
- ONTAP 9
- FASシリーズ
問題
理由コード 0x9 と応答コード 0x8001 が EMS で報告された "scsitarget.hwpfct.mserr" エラー。
ログスニペット:
Fri Aug 28 16:08:05 0000 [Cluster1-01: fct_tpd_work_thread_0: scsitarget.hwpfct.mserr:debug]: The Fibre Channel fabric management server request (GID_PT) sent from adapter 0e failed with reason code 0x9 (Server unable to perform operation), explanation code 0xa (Port type not registered), and response code 0x8001. Fri Aug 28 16:08:05 0000 [Cluster1-01: fct_tpd_work_thread_0: scsitarget.hwpfct.mserr:debug]: The Fibre Channel fabric management server request (GID_PT) sent from adapter 0f failed with reason code 0x9 (Server unable to perform operation), explanation code 0xa (Port type not registered), and response code 0x8001. Fri Aug 28 16:08:05 0000 [Cluster1-01: fct_tpd_work_thread_0: scsitarget.hwpfct.mserr:debug]: The Fibre Channel fabric management server request (GA_NXT) sent from adapter 0e failed with reason code 0x9 (Server unable to perform operation), explanation code 0x1 (Port id not registered), and response code 0x8001.
