メインコンテンツまでスキップ
Flash Cache NVMe オフラインです
110
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
環境
FAS
問題
  • Flash Cache NVMe オフラインメッセージを受信しました
  • Flash Cache failed can be found in the following command output.
例:
sysconfig -a
 slot 1: Flash Cache NVMe
  Serial Number:      S3K7NX0K301083
  Part Number:        119-00328
  Hardware Revision:  A0
  Firmware Version:   NA01
  Model Name:         X3310A
  Capacity:           512 GB
  State:              failed
event log show
[?] Fri Jul 24 23:54:38 CST [FAS2650: wafl_exempt02: ems.engine.suppressed:debug]: Event 'extCache.io.writeError' suppressed 18702 times in last 3041892 seconds.
[?] Fri Jul 24 23:54:38 CST [FAS2650: wafl_exempt02: extCache.io.writeError:notice]: WAFL external cache I/O write error: Insertq_save: unable to set up context chain, code 0.
[?] Fri Jul 24 23:55:28 CST [FAS2650: gemini-notif-thread: callhome.nvme.offline:alert]: Callhome for Flash Cache NVMe Offline.
  • パニックが発生し、次のパニック文字列が生成されます。
WAFL hung for <aggr_name>. in SK process wafl_exempt02 on release 9.4P3 (C)
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
  • この記事は役に立ちましたか?
