FAS2650 で Flash Cache NVMe オフラインです
に適用されます
- FAS2650
- FAS2720
問題
- Flash Cache NVMe オフラインメッセージを受信しました
- Flash Cache failed can be found in the following command output.
例:
sysconfig -a
slot 1: Flash Cache NVMe
Serial Number: S3K7NX0K301083
Part Number: 119-00328
Hardware Revision: A0
Firmware Version: NA01
Model Name: X3310A
Capacity: 512 GB
State: failed
event log show
[?] Fri Jul 24 23:54:38 CST [FAS2650: wafl_exempt02: ems.engine.suppressed:debug]: Event 'extCache.io.writeError' suppressed 18702 times in last 3041892 seconds.
[?] Fri Jul 24 23:54:38 CST [FAS2650: wafl_exempt02: extCache.io.writeError:notice]: WAFL external cache I/O write error: Insertq_save: unable to set up context chain, code 0.
[?] Fri Jul 24 23:55:28 CST [FAS2650: gemini-notif-thread: callhome.nvme.offline:alert]: Callhome for Flash Cache NVMe Offline.
