内部通信の問題が原因でクラスタへのノードの追加が失敗します
- 4
- Visibility:
- Public
- Votes:
- 0
- Category:
- ontap-9
- Specialty:
- core<a>2008956374</a><a>(翻訳用</a>)
- Last Updated:
環境
- ONTAP 9
- FAS/AFF
問題
- 既存のクラスタへの新しいノードの追加が失敗して、次の処理が実行されます。
Joining cluster ..............Error: Cluster applications failed to initialize due to internal communication problems. Run the setup wizard again to resolve the problem. Contact support personnel if the problem persists.
- System Manager に次のアラートが表示されます。
Probable Cause: MTU value "4294967295" on port "e0a" of node
"NODE12" is improperly set. It should be 9000.
Possible Effect: Received Ethernet packets that are larger than the
configured MTU are dropped, causing data transfer issues.
Corrective Actions: modify the MTU using the command "network port
broadcast-domain modify -ipspace Cluster -broadcast-domain Cluster -mtu
To find out the broadcast domain name of the port, execute the command
"network port broadcast-domain show".
