メインコンテンツまでスキップ
スロット11のNVDIMMが、ノードのブート中に「nvdimm.nvmem.initfault:FAULT"」というエラーで失敗します
27
Visibility:
Votes:
0
Category:
fas-systems<a>2009362148</a>
Specialty:
hw
Last Updated:
環境
  • AFF A400
  • AFF A800
  • FAS 8300
  • FAS 8700
  • ONTAP 9
問題
ONTAP のアップグレード中にノードがリブートすると、エラーが表示されてノードがブートできず、パニック状態以下になる
[nvdimm.nvmem.initfail:FAULT]:NVMEM subsystem initialization failed because NVDIMM device in slot-11
failed to configure energy source
NVMEM subsystem failed initialization or configuration check To prevent NVMEM data loss, halt the system.
Set bootarg.init.battery_override can ignore this error and continue to boot.
PANIC : System is going to shutdown because NVMEM subsystem failed initialization or configuration check.
version: 9.10.1P4: Mon May 9 18:11:44 EDT 2022
IPMI device unit 1 rev. 1, firmware rev. 10.03, version 2.0, device support mask oxbf
Sun Mar 5 08:05:02 2023 [nvdimm.nvmem.initfail:FAULT]:NVMEM subsystem initialization failed because NVDIMM device in slot-11 lost persistence due to SDRAM not in self-refresh mode , andNVDIMM HARDWARE error.. To prevent NVMEM data loss, halt the system.
Sun Mar 5 08:05:02 2023 [nvdimm.nvmem.initfail:FAULT]:NVMEM subsystem initialization failed because NVDIMM device in slot-23 lost persistence due to SDRAM not in self-refresh mode , andNVDIMM HARDWARE error.. To prevent NVMEM data loss, halt the system.
Sun Mar 5 08:05:02 2023 [nvdimm.nvmem.destage.failure:ALERT]:NVMEM subsystem failed to copy nonvolatile data to flash memory on NVDIMM device because SDRAM is not in self-refresh mode, and because of a hardware error..
New to NetApp?
  • この記事は役に立ちましたか?
