メインコンテンツまでスキップ
BMC 11.6で互換性のないパートナーPCMが報告されているノード
22
Visibility:
Votes:
0
Category:
aff-series
Specialty:
hw
Last Updated:
環境
  • AFF A220
  • FAS2720
  • BMC 11.8以前
問題
  • ノードからAutoSupportが送信される対象は次のとおりです。
System Alert from SP of node-01 (INVALID CHASSIS CONFIGURATION (Incompatible Partner PCM)) CRITICAL
  • EMSレポート:
[?] Tue Jun 28 02:22:30 +0000 [node-01: env_mgr: monitor.temp.unreadable:error]: The controller temperature (Midplane 4 Temp) is not readable.
[?] Tue Jun 28 02:22:30 +0000 [node-01: env_mgr: monitor.temp.unreadable:error]: The controller temperature (Midplane 3 Temp) is not readable.
[?] Tue Jun 28 02:22:30 +0000 [node-01: env_mgr: monitor.temp.unreadable:error]: The controller temperature (Midplane 2 Temp) is not readable.
[?] Tue Jun 28 02:22:30 +0000 [node-01: env_mgr: monitor.temp.unreadable:error]: The controller temperature (Midplane 1 Temp) is not readable.[?] Tue Jun 28 02:22:43 +0000 [node-01: rlm_hbtrcv_non_blocking: sp.update.status:debug]: params: {'reason': 'sp_bootup_notify_servprocd: SP online handler has been called  '}
[?] Tue Jun 28 02:22:44 +0000 [node-01: cf_worker: cf.hwassist.notifyCfgSuccess:debug]: params: {'hwtype': 'SP'}
[?] Tue Jun 28 02:23:16 +0000 [node-01: env_mgr: monitor.fan.warning:notice]: multiple fans have failed. Replace it to avoid overheating
[?] Tue Jun 28 02:23:46 +0000 [node-01: env_mgr: callhome.c.fan.fru.fault:error]: Call home for CHASSIS FAN FRU FAILED: Multiple fans have failed
  • sp -latest-ipmi/system sensors show:センサーを読み取れないことを示します。
PSU2 Bad                 invalid            --
PSU1 Bad                 invalid            --
PSU2                     invalid            --
PSU1                     invalid            --
PSU2 ON                  invalid            --
PSU1 ON                  invalid            --
PSU1 INFO                               FAILED
PSU1 INFO                               FAILED
PSU1 FRU                                MULTIFAULT
PSU2 FRU                                MULTIFAULT
Partner Status           failed             --
PSU1 Present                            PRESENT
PSU1 5V                  init_failed       -- mV       --          --          --          --
PSU1 12V                 init_failed       -- mV       --          --          --          --
PSU1 5V Curr             init_failed       -- mA       --          --          --          --
PSU1 12V Curr            init_failed       -- mA       --          --          --          --
PSU1 Fan 1               init_failed       -- RPM      --          --          --          --
PSU1 Fan 2               init_failed       -- RPM      --          --          --          --
PSU1 Inlet Temp          init_failed       -- C        --          --          --          --
PSU1 Hotspot Temp        init_failed       -- C        --          --          --          --
PSU2 Present                            PRESENT
PSU2 5V                  init_failed       -- mV       --          --          --          --
PSU2 12V                 init_failed       -- mV       --          --          --          --
PSU2 5V Curr             init_failed       -- mA       --          --          --          --
PSU2 12V Curr            init_failed       -- mA       --          --          --          --
PSU2 Fan 1               init_failed       -- RPM      --          --          --          --
PSU2 Fan 2               init_failed       -- RPM      --          --          --          --
PSU2 Inlet Temp          init_failed       -- C        --          --          --          --
PSU2 Hotspot Temp        init_failed       -- C        --          --          --          --
PSU_FAN                  failed             --
Module B Expander Temp   init_failed       -- C        --          --          --          --
Module A Expander Temp   init_failed       -- C        --          --          --          --
Midplane 4 Temp          failed            -- C         0 C         5 C        47 C        52 C
Midplane 3 Temp          failed            -- C         0 C         5 C        47 C        52 C
Midplane 2 Temp          failed            -- C         0 C         5 C        47 C        52 C
Midplane 1 Temp          failed            -- C         0 C         5 C        47 C        52 C
Ambient Temp             init_failed       -- C        --          --          --          --
Internal Shelf           failed             --
New to NetApp?
