メインコンテンツまでスキップ
NetApp wins prestigious Coveo Relevance Pinnacle Award. Learn more!
INSIGHT Japan :2023年 1月25日(水)ANAインターコンチネンタルホテル開催 へ参加・申込を行う
ONTAP 9.8 with OKM :キーが見つからないため、ギブバックが断続的に失敗します
17
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
問題
  • ブート中に ONTAP 9.8 ノードに OKM を追加すると、オンボードキー階層をインポートできません
 Tue Oct 05 12:06:01 -0500 [Clus-02: sysinit_thread: crypto.debug:info]: cryptomod key table initialized with room for 10 keys (0 pages). Tue Oct 05 12:06:01 -0500 [Clus-02: sysinit_thread: crypto.ssal.failed:alert]: SSAL operation failed: SSAL Unseal operation failed. Tue Oct 05 12:06:01 -0500 [Clus-02: sysinit_thread: crypto.debug:info]: Onboard key hierarchy import failed: failed to create NKEK: 31. Tue Oct 05 12:06:01 -0500 [Clus-02: sysinit_thread: crypto.okmrecovery.failed:alert]: ERROR: Import of the onboard key hierarchy failed: failed to import key hierarchy. Additional information: error: ssal unseal failedWed Oct 05 12:10:01 -0500 [Cluster01-01: cf_giveback: gb.sfo.veto.kmgr.keysmissing:error]: Giveback of aggregate Aggr_1 failed due to unavailability of volume encryption keys for the encrypted volumes of the aggregate on the partner node Cluster01-02. ... Tue Oct 05 12:07:01 -0500 [Clus-02: rc: cf.fm.waitingForGB:debug]: params: {'reason': 'WFG: partner f/w state is SF_TO'} Tue Oct 05 12:09:40 -0500 [Clus-02: clam.node.inq:info]: Cluster node (name=CS_OTH_TR2_PRD1-01, ID=1000) is in "CLAM quorum". Tue Oct 05 12:09:40 -0500 [Clus-02: clam.node.avail.change:debug]: The availability status of node (name=CS_OTH_TR2_PRD1-01, ID=1000) changed from Unknown to Available. ... Tue Oct 05 12:10:01 -0500 [Clus-02: monitor: monitor.globalStatus.ok:notice]: The system's global status is normal. ​Tue Oct 05 12:10:01 -0500 [Clus-02: monitor: license.state.v2.modified:debug]: Licensing state for local node changed from false to true.​​​​
  • ONTAP 9.8 パートナーノードでは、キーがないために SFO ギブバックが拒否されます
 Tue Oct 05 12:10:01 -0500 [Clus-01: cf_giveback: sfo.sendhome.subsystemAbort:alert]: The giveback operation of 'Aggr_1' was aborted by 'keymanager' Tue Oct 05 12:10:01 -0500 [Clus-01: sfo.giveback.failed:alert]: Giveback of aggregate Aggr_1 failed due to Giveback was vetoed.. Tue Oct 05 12:10:01 -0500 [Clus-01: The giveback operation of 'Aggr_1' was aborted by 'keymanager'. Tue Oct 05 12:10:01 -0500 [Clus-01: sfo.retry.autoGiveback:info]: Automatic giveback of SFO aggregates will be retried after 5 minutes. ​​​​... Tue Oct 05 12:15:01 -0500 [Clus-01: cf_giveback: gb.sfo.veto.kmgr.keysmissing:error]: Giveback of aggregate Aggr_1 failed due to unavailability of volume encryption keys for the encrypted volumes of the aggregate on the partner node Cluster01-02. Tue Oct 05 12:15:01 -0500 [Clus-01: cf_giveback: sfo.sendhome.subsystemAbort:alert]: The giveback operation of 'Aggr_1' was aborted by 'keymanager' ​​​Tue Oct 05 12:15:01 -0500 [Clus-01: The giveback operation of 'Aggr_1' was aborted by 'keymanager'. Tue Oct 05 12:15:01 -0500 [Clus-01: sfo.giveback.attemptExceeded:alert]: Attempts for automatic giveback of SFO aggregates exceeded the maximum number (3) of allowed attempts.
New to NetApp?
Scan to view the article on your device
