ONTAP が「エンドポイント環境変数の構築に失敗しました」というメッセージでブートに失敗しました
のしんだ
環境
問題
- 次のエラーメッセージが表示され、自動ブートが失敗します。
BIOS Version: 11.7
Portions Copyright (C) 2014-2018 NetApp, Inc. All Rights Reserved.
Initializing System Memory ...
Loading Device Drivers ...
Configuring Devices ...
CPU = 1 Processor(s) Detected.
Intel(R) Xeon(R) CPU D-1557 @ 1.50GHz (CPU 0)
CPUID: 0x00050664. Cores per Processor = 12
32768 MB System RAM Installed.
Boot Loader version 6.0.8
Copyright (C) 2000-2003 Broadcom Corporation.
Portions Copyright (C) 2002-2018 NetApp, Inc. All Rights Reserved.
ERROR: Failure to build endpoint environment variables. Autoboot will be disabled.
- BMC イベント ALL
[Controller.notice]: Appliance user command panic.
[IPMI.notice]: 001f | 02 | EVT: 6f406fff | Sensor 255 | Assertion Event, "Storage OS stop/shutdown"
[BMC.critical]: Filer Reboots
[IPMI.notice]: 0020 | 02 | EVT: 6fc200ff | System_FW_Status | Assertion Event, "Unspecified"
[BMC.notice]: PCIE Config Info received from BIOS
[BMC.notice]: ScratchPad Config Info received from BIOS
[IPMI.notice]: 0021 | 02 | EVT: 6fc21fff | System_FW_Status | Assertion Event, "System Firmware restarting"
[SysFW.notice]: SP responded to sync command in 0 seconds.
[SysFW.notice]: BIOS Version: 11.4
[IPMI.notice]: 0022 | 02 | EVT: 6fc201ff | System_FW_Status | Assertion Event, "Memory initialization in progress"
[IPMI.notice]: (PUA) Enable power to all PCIe slots
[IPMI.notice]: (PUA) Enable power to all PCIe on board device
[IPMI.notice]: (PUA) P_stat :slots=0x0,onboard_devs=0x0,final
[IPMI.notice]: (PUA) Power status of all PCIe slots unchanged
[IPMI.notice]: 0023 | 02 | EVT: 6fc203ff | System_FW_Status | Assertion Event, "Memory Initialization done"
[SysFW.warning]: Error loading ENV variables, creating defaults
[SysFW.warning]: Failed to read FW image on boot media: Device not found. Auto up
[SysFW.warning]: date skipped
[IPMI.notice]: 0024 | 02 | EVT: 6fc220ff | System_FW_Status | Assertion Event, "Bootloader is running"
[BMC.critical]: Heartbeat stopped
