パニック:システムIDがないか無効です
環境
- AFF A700
- FAS9000
問題
- 次のパニックが発生します
WARNING: Unable to get sysid!
PANIC : Missing/invalid System ID: bootarg.frurom.fileid=<0>.
version: 9.7P5: Tue Jun 23 00:04:35 EDT 2020
conf : x86_64.optimize
cpuid = 14
Uptime: 16s
ahcich0: AHCI reset done: devices=00000001
coredump: primary dumper is not yet registered this early during system initialization. A coredump will not be available at this time.
coredump: secondary dumper is not yet registered this early during system initialization. A coredump will not be available at this time.
System halting...
BIOS Version: 10.7
Portions Copyright (C) 2014-2017 NetApp, Inc. All Rights Reserved.
Initializing System Memory ...
Loading Device Drivers ...
IPMI PCI Slot Configuration failed.
Configuring Devices ...
Device(s) in slot missing, attempting to recover it.
System is resetting.
BIOS Version: 10.7
CPU = 2 Processor(s) Detected.
Intel(R) Xeon(R) CPU E5-2697 v4 @ 2.30GHz (CPU 0)
CPUID: 0x000406F1. Cores per Processor = 18
Intel(R) Xeon(R) CPU E5-2697 v4 @ 2.30GHz (CPU 1)
524288 MB System RAM Installed.
SATA (AHCI) Device: SV9MST6D120GLM41NP
Boot Loader version 6.0.8
Copyright (C) 2000-2003 Broadcom Corporation.
Portions Copyright (C) 2002-2018 NetApp, Inc. All Rights Reserved.
BIOS POST Failure(s) detected: PCIe device missing error detected. Abort AUTOBOOT
partner-sysid
printenvの出力にがありません
LOADER-B> printenv
Variable Name Value
ARCH X86_64
AUTOBOOT true
AUTOBOOT_FROM PRIMARY
AUTO_FW_UPDATE true
BACKUP_BIOS_VERSION 10.5
BIOS_DATE Tue 10/22/2019
BIOS_INTERFACE 40000000000400C7
BIOS_VERSION 10.7
BOARDNAME SB_XXI
bootarg.frurom.fileid 0
bootarg.init.flash_optimized true
BOOTED_FROM OTHER
boot_backup setenv BOOTED_FROM BACKUP; boot -elf64 $GX_BACKUP_KERNEL_URL
BOOT_CONSOLE eficons0a
boot_diags boot -sld -elf64 $GX_DIAG_URL
BOOT_FLASH flash0a
boot_ontap autoboot
boot_primary setenv BOOTED_FROM PRIMARY; boot -elf64 $GX_PRIMARY_KERNEL_URL
BT_BIOS_VERSION 10.7
BT_LOADER_VERSION 6.0.8
CPU_NUM_CORES 36
CPU_SPEED 2300
CPU_TYPE Intel(R) Xeon(R) CPU E5-2697 v4 @ 2.30GHz
ENABLE_SMI false
ENV_VERSION 1
FIRMWARE_URL fat://boot0/X86_64/firmware/SB_XXI/firmware.img
GX_BACKUP_KERNEL_URL fat://boot0/X86_64/freebsd/image2/kernel
GX_DIAG_URL fat://boot0/X86_64/freebsd/image1/kernel
GX_PRIMARY_KERNEL_URL fat://boot0/X86_64/freebsd/image1/kernel
ldkern load -elf64 $GX_PRIMARY_KERNEL_URL
MOBO_MODEL FAS9000
MOBO_REV F0
MOBO_SERIAL_NUM 031939000543
MOBO_VENDOR NetApp, Inc.
netboot setenv BOOTED_FROM NETWORK; boot -elf64
ntap.init.kernelname X86_64/freebsd/image1/kernel
OEM_TYPE_2/0/29/0/0x8086/0x8D26 0/u/b
OEM_TYPE_2/0/31/2/0x8086/0x8D02 0/u/a
OEM_TYPE_2/173/0/0/0x11F8/0x8072 9/#/#
OEM_TYPE_2/207/0/0/0x10B5/0x8732 10/#/#
OEM_TYPE_2/208/8/0/0x10B5/0x8732 10/#/#
OEM_TYPE_2/208/9/0/0x10B5/0x8732 10/#/#
OEM_TYPE_2/209/0/0/0x8086/0x1584 10/#/#
OEM_TYPE_2/210/0/0/0x8086/0x1584 10/#/#
OEM_TYPE_2/57/0/0/0x10B5/0x8732 4/#/#
OEM_TYPE_2/58/8/0/0x10B5/0x8732 4/#/#
OEM_TYPE_2/58/9/0/0x10B5/0x8732 4/#/#
OEM_TYPE_2/59/0/0/0x8086/0x1584 4/#/#
OEM_TYPE_2/59/0/1/0x8086/0x1584 4/#/#
OEM_TYPE_2/59/0/2/0x8086/0x1584 4/#/#
OEM_TYPE_2/59/0/3/0x8086/0x1584 4/#/#
OEM_TYPE_2/60/0/0/0x8086/0x1584 4/#/#
OEM_TYPE_2/60/0/1/0x8086/0x1584 4/#/#
OEM_TYPE_2/60/0/2/0x8086/0x1584 4/#/#
OEM_TYPE_2/60/0/3/0x8086/0x1584 4/#/#
OEM_TYPE_2/96/0/0/0x8086/0x1533 0/e/M
OEM_TYPE_3 0/0/31/2/u0a.0/SV9MST6D120GLM41NP;
OEM_TYPE_4 32768/0/4096/0xC7FE8000
PRIMARY_BIOS_VERSION 10.7
savenv saveenv
sysvar.init.boot.varfs.restore.success true
SYS_MODEL FAS9000
SYS_REV A1
SYS_SERIAL_NUM xxxxxxxxxxxxx
update_flash flash -backup $FIRMWARE_URL flash0a
USE_SECONDARY false
vm.pci.mmio.64.addr 0xc000000000
vm.pci.mmio.64.size 0x3ffc000000
Slot 6 missing
イベントallの出力に表示されます
Record 2444: Mon May 16 02:53:06.837889 2022 [SP.notice]: PCIE Config Info received from BIOS
Record 2445: Mon May 16 02:53:06.894052 2022 [SP.notice]: ScratchPad Config Info received from BIOS
Record 2446: Mon May 16 02:53:10.215127 2022 [IPMI.notice]: (PUA) Enable power to all PCIe slots
Record 2447: Mon May 16 02:53:10.224249 2022 [IPMI.notice]: (PUA) Enable power to all PCIe on board device
Record 2448: Mon May 16 02:53:10.000000 2022 [SysFW.notice]: BIOS Version: 10.7
Record 2449: Mon May 16 02:53:10.274365 2022 [IPMI.notice]: (PUA) P_stat :slots=0x0,onboard_devs=0x0,final
Record 2450: Mon May 16 02:53:10.274422 2022 [IPMI.notice]: (PUA) Power status of all PCIe slots unchanged
Record 2451: Mon May 16 02:53:16.564218 2022 [IPMI.notice]: 7502 | 02 | EVT: 01500f14 | Bat_Rem_Cap | Assertion Event, "Lower Non-critical going low " | Reading: 0.375 | Threshold: 0.500
Record 2452: Mon May 16 02:53:19.000000 2022 [SysFW.critical]: IPMI PCI Slot Configuration failed.
Record 2453: Mon May 16 02:53:19.432640 2022 [Trap Event.critical]: hwassist post_error (26)
Record 2454: Mon May 16 02:53:24.000000 2022 [SysFW.notice]: Device 94/0/0 (SLOT-6-CPU0) missing
Record 2455: Mon May 16 02:53:25.456187 2022 [IPMI.notice]: 7602 | 02 | EVT: 6f02ffff | PCM_Status | Assertion Event, "Fault"
Record 2456: Mon May 16 02:53:27.000000 2022 [SysFW.notice]: Device(s) in slot missing, attempting to recover it.
