電源装置が DC 障害、 AC 障害、オフを報告しています
に適用されます
- FAS8020
- DS2246
問題
電源装置のレポート:
::> storage shelf show -shelf <channel>.<shelfID> -power -instance Power Supply Units: Crest Power Reset PSU Operational ID Type Part# Serial# Power Rating Factor Drawn Capable Enabled Firmware Status PSU Location --- ---- ------------ --------------- -------------- ------ ------- ------- ------- -------- ---------------- ------------------------ 1 9C 114-00027+D0 PSD01B184505690 - - - false true 020F normal rear of the shelf at the bottom left 2 9C 114-00065+B0 PSD041150378463 - - - false true 020F off rear of the shelf at the bottom right Voltage Sensors: Voltage Operational ID (V) Status Sensor Location --- ------- ---------------------- ------------------------ 1 5.70 normal rear of the shelf on the lower left power supply 2 12.300 normal rear of the shelf on the lower left power supply 3 - not-recoverable rear of the shelf on the lower right power supply 4 - not-recoverable rear of the shelf on the lower right power supply Current Sensors: Current Operational ID (mA) Status Sensor Location --- ------- ---------------------- ------------------------ 1 9760 normal rear of the shelf on the lower left power supply 2 8350 normal rear of the shelf on the lower left power supply 3 0 normal rear of the shelf on the lower right power supply 4 0 normal rear of the shelf on the lower right power supply
