メインコンテンツまでスキップ
システムのブートアップが失敗し、マザーボード交換後に「 WARNING : 0 disks found 」エラーが表示されます
10
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
に適用されます
  • FASシステム
  • AFFシステム
問題
  • 次のエラーが表示されて、システムが起動し、再起動が繰り返し失敗します。
WARNING: 0 disks found!
Storage Adapters found:
0 Fibre Channel Storage Adapters found!
2 SAS Adapters found!
0 Parallel SCSI Storage Adapters found!
0 ATA Adapters found!
Target Adapters found:
0 Fibre Channel Target Adapters found!
2 iSCSI Target Adapters found!
1 Unknown Target Adapters found!
WARNING: there do not appear to be any disks attached to the system.
Jan 15 18:49:54 [localhost:cf.fm.noMBDisksOrIc:warning]: Could not find the local mailbox disks. Could not determine the firmware state of the partner through the HA interconnect.
No root volume found.
Jan 15 18:49:55 [localhost:zapi.sf.up.ready:info]: ZAPI: system node stable after startup.
Rebooting... (press ctrl-c during boot to break reboot loop)
Uptime: 1m17s
System rebooting...
  • 古いマザーボードは、マザーボードの交換後もディスク所有者のままです。手順
*> disk show  -v
Local System ID: 333333333
  DISK       OWNER                    POOL   SERIAL NUMBER         HOME                     DR HOME                CHKSUM
0a.00.8      node-1  (111111111)    Pool0  Y5bxxxxxxxxx          node-1  (111111111)                          Block
0b.00.11     node-1  (111111111)    Pool0  Y5cxxxxxxxxx          node-1  (111111111)                          Block
0a.00.10     node-1  (111111111)    Pool0  Y5dxxxxxxxxx          node-1  (111111111)                          Block
0b.00.3      node-1  (111111111)    Pool0  Y5exxxxxxxxx          node-1  (111111111)                          Block
0b.00.9      node-1  (111111111)    Pool0  Y5fxxxxxxxxx          node-1  (111111111)                          Block
0b.00.5      node-1  (111111111)    Pool0  Y5gxxxxxxxxx          node-1  (111111111)                          Block
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
