メインコンテンツまでスキップ
バッテリは充電を要求していないにもかかわらず、 NVMEM バッテリ充電器がバッテリを充電しています
12
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
に適用されます
  • Data ONTAP 8
  • サービス プロセッサ(SP)
問題
  • システムにバッテリ充電エラーがあり、短時間に自動的に修正されます。
例:
Tue Jul 14 08:34:43 CST [shadcpsamc2620-02: env_mgr: nvmem.battery.wrongCharge:alert]: The NVMEM battery charger is charging the battery even though the battery is not requesting to be charged. To prevent data loss, the system will shut down in 24 hours.
Tue Jul 14 08:34:53 CST [shadcpsamc2620-02: env_mgr: nvmem.battery.normalCharge:notice]: The NVMEM battery charging status is normal.
  • system node environment sensors showバッテリの充電が正常であることを確認します。
例:
Bat Present                             PRESENT
Bat Temp                 normal            29 C         0 C         5 C        60 C        75 C
Bat Volt                 normal          8100 mV     5500 mV     5600 mV     8500 mV     8600 mV
Bat Pct Capacity         normal            96 %        39 %        44 %        --          --
Bat Curr                 normal             0 mA       --          --        1200 mA     1520 mA
Bat Rem Cap              normal          1536 mA*hr    --          --          --          --
Bat Full Cap             normal          1536 mA*hr    --          --          --          --
Bat Charge Curr          normal             0 mA       --          --        2200 mA     2300 mA
Bat Charging State                        IDLE
Bat Charge Volt          normal          8200 mV       --          --        8900 mV     9000 mV
Bat Initial FCC          normal          1600 mA*hr    --          --          --          --
Bat Dstg Cycles          normal            26 cycles    2 cycles    5 cycles   --          --
Bat Power Fault                           GOOD
Bat Dcharge FET                             ON
Bat Charge FET                              ON
Bat Cycle Count          normal            15 cycles   --          --          --          --
Bat Learning Active                        OFF
Bat Pack Invalid                            OK
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
