関係に対する別の SnapMirror 処理が実行中であるため、スケジュールされた更新が遅延しました
環境
- ONTAP 9
- SnapMirror
- Commvault
問題
snapmirror show -instance
コマンドを実行すると、がRelationship Status
Transferring
長時間経過していることが示されます。- 関係レポートは次のとおりです。
Healthy: false
Unhealthy Reason: Scheduled update failed to start. (Scheduled update was delayed because another SnapMirror operation for the relationship is in progress.)
- 次のメッセージも報告されることがあります。
Alert on mirror copies - smc.snapmir.schd.trans.overrun: Scheduled transfer from source volume 'volume_name' to destination volume 'volume_name' is taking longer than the schedule window.
例:
cluster::> snapmirror show -instance
Source Path: S_SVM:vol1
Destination Path: D_SVM:vol_dr
Relationship Type: XDP
Relationship Group Type: none
SnapMirror Schedule: 8hour
SnapMirror Policy Type: async-mirror
SnapMirror Policy: MirrorAllSnapshots
Tries Limit: -
Throttle (KB/sec): 18432
Mirror State: Snapmirrored
Relationship Status: Transferring
File Restore File Count: -
File Restore File List: -
Transfer Snapshot: snapshot_for_backup.332
Snapshot Progress: 2.77TB
Total Progress: 2.77TB
Network Compression Ratio: 1:1
Snapshot Checkpoint: 2.77TB
Newest Snapshot: snapmirror.b11611fc-3243-11ec-9316-a039ea34eb5f_2147597238.2022-04-20_180110
Newest Snapshot Timestamp: 02/25 18:01:01
Exported Snapshot: snapmirror.b11611fc-3243-11ec-9316-a039ea34eb5f_2147597238.2022-04-20_180110
Exported Snapshot Timestamp: 02/25 18:01:01
Healthy: false
Destination Volume Node: FAS8300_B
Relationship ID: 712de9bc-961c-10ec-b7b6-d039ea34eb5f
Current Operation ID: 72ffe34a-143f-4080-9e24-ac0a27738877
Transfer Type: update
Transfer Error: -
Current Throttle: 18432
Current Transfer Priority: normal
Last Transfer Type: update
Last Transfer Error: -
Last Transfer Size: 0B
Last Transfer Network Compression Ratio: 1:1
Last Transfer Duration: 0:0:0
Last Transfer From: S_SVM:vol1
Last Transfer End Timestamp: 04/18 12:57:30
Progress Last Updated: 04/20 15:11:03
Relationship Capability: 8.2 and above
Lag Time: 137:10:10
Identity Preserve Vserver DR: -
Volume MSIDs Preserved: -
Is Auto Expand Enabled: -
Number of Successful Updates: 1
Number of Failed Updates: 0
Number of Successful Resyncs: 0
Number of Failed Resyncs: 0
Number of Successful Breaks: 0
Number of Failed Breaks: 0
Total Transfer Bytes: 47809824496619
Total Transfer Time in Seconds: 4560980
