ONTAP にスイッチ管理 IP が表示されない場合、サポートされない switch_alert が実行されています
環境
- クラスタ スイッチ
- ONTAP 9
問題
UNSUPPORTED SWITCH_ALERT
はEMSで報告されます。
[Netapp01: mgwd: callhome.hm.alert.major:alert]: Call home for Health Monitor process cshm: UnsupportedSwitch_Alert[Switch-01].
system health alert show -monitor cluster-switch -instance
詳細情報を表示します。
Node: c-bdo1-01
Resource: c-bdo-sw2
Severity: Major
Indication Time: Tue Aug 03 13:58:52 2021
Suppress: false
Acknowledge: false
Probable Cause: Unsupported Ethernet switch is detected.
Possible Effect: Communication problems and network connectivity issues occur.
Corrective Actions: Unsupported Ethernet switch "c-bdo-sw2" found. Connect a supported Ethernet switch to the network.
Invalid SNMP Settings
で報告されていますsystem cluster-switch show
Switch Type Address
Model
switch1 cluster-network 10.0.1.0 OTHER
Serial Number: Unknown
Is Monitored: false
Reason: Invalid SNMP Settings
Software Version: 3.4.4.6
Version Source: CDP/ISDP
switch2 cluster-network 10.0.2.0 OTHER
Is Monitored: false
Version Source:
CDP/ISDP
