snapmirror previous updateがまだ実行中で、次回の更新が行われたときの動作
環境
- ONTAP 9
- SnapMirror
回答
snapmirror show -
instance
コマンドRelationship Status
Transferring
を実行すると、が長時間にわたってあることが表示されます。- 関係レポートは次のとおりです。
Healthy: false
Unhealthy Reason: Scheduled update failed to start. (Scheduled update was delayed because another SnapMirror operation for the relationship is in progress.)
- このメッセージは次のように報告されることもあります。
Alert on
mirror copies - smc.snapmir.schd.trans.overrun: Scheduled transfer from source volume 'volume_name' to destination volume 'volume_name' is taking longer than the schedule window.
例:
cluster::> snapmirror show cluster2:volname -instance
Source Path: cluster1:volname
Destination Path: cluster2:volname
Relationship Type: XDP
Relationship Group Type: none
SnapMirror Schedule: snapvault
SnapMirror Policy Type: vault
SnapMirror Policy: snapvault_vault
Tries Limit: -
Throttle (KB/sec): unlimited
Mirror State: Snapmirrored
Relationship Status: Transferring
File Restore File Count: -
File Restore File List: -
Transfer Snapshot: daily.2019-12-20_0010
Snapshot Progress: 6.78GB
Total Progress: 6.78GB
Network Compression Ratio: 1:1
Snapshot Checkpoint: 6.66GB
Newest Snapshot: daily.2019-12-19_0010
Newest Snapshot Timestamp: 12/19 00:10:03
Exported Snapshot: daily.2019-12-19_0010
Exported Snapshot Timestamp: 12/19 00:10:03
Healthy: false
