メインコンテンツまでスキップ
Extreme networks VDX8770 switch は、ファン rpm を高くレポートします
12
Visibility:
Votes:
0
Category:
fabric-interconnect-and-management-switches
Specialty:
brocade
Last Updated:
環境
Extreme Networks VDX8770 スイッチ
問題
  • スイッチの温度が高くなり、ファンが高くなります RPM は非常に騒音の多い環境につながっています
  • イベントログには、ブレードの温度が高くなっていることが示されています
2020/01/13-13:38:35:993021, [HIL-5600], 398250/0, M1 | Active, WARNING, VDX6740T-1G, Fan speed changing per environmental specifications.  Reason: Blade in max temp range (currently max fan speed)., hil_policy_chas, line: 559, comp:emd, ltime:2020/01/13-13:38:35:992849
2020/01/13-13:38:53:586722, [HIL-5600], 398252/0, M1 | Active, WARNING, VDX6740T-1G, Fan speed changing per environmental specifications.  Reason: Blade in max temp range (currently max fan speed)., hil_policy_chas, line: 559, comp:emd, ltime:2020/01/13-13:38:53:586514
2020/01/13-13:39:11:182804, [HIL-5600], 398254/0, M1 | Active, WARNING, VDX6740T-1G, Fan speed changing per environmental specifications.  Reason: Blade in max temp range (currently max fan speed)., hil_policy_chas, line: 559, comp:emd, ltime:2020/01/13-13:39:11:182586
  • この例のファン速度は 9000rpm で、通常の動作範囲は 5000~6000rpm です
NOSCLI show environment fan:
Mon Jan 13 13:16:35 GMT 2020
Rbridge-id: 1
Fan 1 is Ok, speed is 9132 RPM
Fan 2 is Ok, speed is 9174 RPM
Fan 3 is Ok, speed is 9049 RPM
Fan 4 is Ok, speed is 9090 RPM
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
