パニックメッセージ :cshmd:assertion(0) at src/tables/switch_info_resource.cc:795 が失敗しました
環境
BES-53248
問題
スイッチの移行後、次のように表示されます
ALERT spm.cshmd.process.exit: Cluster Switch Health
Monitor process (cshmd) with ID 86409 exited as a result of signal 6. This server will attempt to restart.Panic Message :
cshmd: assertion (0) at src/tables/switch_info_resource.cc:795 failed, raising SIGABRT(6) at RIP 0x807967d9a-Eventually the ucores filled up the root volume and panicked the node
-Customer deleted the cores and freed up the space on the node
