アラート ID = NodeSwitchPortMTU_Alert 、監視クラスタスイッチによって生成されたレベル
環境
- FAS8020
- ONTAP 9.7
問題
- アラートが繰り返しトリガーされるため、クラスタネットワークに問題はありません。
- EMS - ログアラート:
Sat Apr 24 10:19:55 +0200 [node_name: cshmd: hm.alert.raised:alert]: Alert Id = NodeSwitchPortMTU_Alert , Alerting Resource = Clusterswitch/Slot: 0 Port: 3 10G - Level raised by monitor cluster-switch
Sat Apr 24 10:25:17 +0200 [node_name: cshmd: hm.alert.cleared:notice]: Alert Id = NodeSwitchPortMTU_Alert , Alerting Resource = Clusterswitch/Slot: 0 Port: 3 10G - Level cleared by monitor cluster-switch
- VIFMGR AutoSupport メッセージ:
Sun May 23 2021 07:05:25 02:00 [kern_vifmgr:info:6596] dsmdb_modify_imp_2() on vifmgr_netports_get_remote_device_info failed: xxx.xxx.xx.xxx{ffffffff|ffffffff} prog=536873492 server=vifmgr: RPC: Timed out; netid=tcp fd=73 TO=25.0s TT=25.000s O=260b I=0b CN=379089/1 VSID=-3
Sun May 23 2021 07:05:26 02:00 [kern_vifmgr:info:6677] dsmdb_get_imp_2() on bootconf_netports failed: 127.0.0.1{ffffffff|ffffffff} prog=536873488 server=mgwd: RPC: Timed out; netid=tcp fd=79 TO=25.0s TT=25.015s O=452b I=0b CN=549571/1 VSID=-3
- サービスプロセッサのコンソールログ:
g_vfs_done():md0.uzip: UZIP(zlib) inflate() failed
vm_fault: pager read error, pid 38867 (mntsvc) [retry 4]
md0.uzip[READ(offset=430080000, length=8192)]md0.uzip: UZIP(zlib) inflate() failed
error = 86
g_vfs_done():vm_fault: pager read error, pid 15995 ( httpd) [retry 4]
md0.uzip[READ(offset=636903424, length=8192)]md0.uzip: UZIP(zlib) inflate() failed
error = 86
g_vfs_done():vm_fault: pager read error, pid 2606 (mgwd) [retry 7]
md0.uzip[READ(offset=880058368, length=8192)]error = 86
g_vfs_done():vm_fault: pager read error, pid 16547 (vserverdr) [retry 8]
md0.uzip[READ(offset=1192075264, length=8192)]error = 86
g_vfs_done():vm_fault: pager read error, pid 16538 (upgrademgr) [retry 6]
