スイッチの電源再投入後にクラスタスイッチの ISL が停止しています
環境
CN1610 クラスタネットワークスイッチ
問題
- スイッチの電源再投入後、ファイラーが ISL を停止していると報告しています
The cable used to connect switch "CN1610-1/ Link Aggregate 1" to the ISL port might be faulty. For port-channel, please check each individual link.
The cable used to connect switch "CN1610-1/Slot: 0 Port: 13 10G - Level" to the ISL port might be faulty. For port-channel, please check each individual link.
The cable used to connect switch "CN1610-1/Slot: 0 Port: 14 10G - Level" to the ISL port might be faulty. For port-channel, please check each individual link.
The cable used to connect switch "CN1610-1/Slot: 0 Port: 15 10G - Level" to the ISL port might be faulty. For port-channel, please check each individual link.
The cable used to connect switch "CN1610-1/Slot: 0 Port: 16 10G - Level" to the ISL port might be faulty. For port-channel, please check each individual link.
The cable used to connect switch "CN1610-2/ Link Aggregate 1" to the ISL port might be faulty. For port-channel, please check each individual link.
