ノードがパニック状態になり、リブート時にクラスタに追加できなくなります
- 19
- Visibility:
- Public
- Votes:
- 0
- Category:
- metrocluster
- Specialty:
- metrocluster<a>2009257855</a>
- Last Updated:
環境
- FAS2750
- AFF-A250
- MCC-IP(MetroCluster IP)
- MetroCluster スイッチのRCFアップグレード
問題
- MCC-IP内のスイッチにRCFをアップグレードすると、一方のコントローラでクラムパニックが発生します
Aug 01 17:40:16 [node01:vifmgr.clus.linkdown:EMERGENCY]: The cluster port e0a on node Node-01 has gone down unexpectedly. Aug 01 17:47:34 [node01:vifmgr.clus.linkdown:EMERGENCY]: The cluster port e0a on node Node-01 has gone down unexpectedly. Aug 01 17:52:10 [node01:vifmgr.clus.linkdown:EMERGENCY]: The cluster port e0a on node Node-01 has gone down unexpectedly. Aug 01 18:21:34 [node01:vifmgr.clus.linkdown:EMERGENCY]: The cluster port e0b on node Node-01 has gone down unexpectedly. PANIC : Received PANIC packet from partner, receiving message is (Coredump and takeover initiated because Connectivity, Liveliness and Availability Monitor (CLAM) has determined this node is out of quorum.)
- クラスタポートe0a/e0bがリブートされていますが、ノードは正常ではありません
::*> network port show -role cluster
Auto-Negot Duplex Speed (Mbps)
Node Port Role Link MTU Admin/Oper Admin/Oper Admin/Oper
node01
e0a cluster up 9000 true/true full/full auto/10000
e0b cluster up 9000 true/true full/full auto/10000
::> cluster show
Node Health Eligibility Epsilon
node01 false true false
node02 false true false
storage failover show
ノードがアプリケーションを開始していないことを報告します
::> storage failover show
Takeover
Node Partner Possible State Description
node01
node02 true Connected to node02
node02
node01 true Connected to node01.
Waiting for cluster applications to
come online on the local node.
Offline applications: vldb, vifmgr,
bcomd, crs, scsi blade, clam.
2 entries were displayed.
