ハートビートがなく、パニックメッセージが報告されないまま、予期しないテイクオーバーでノードがリブートします
環境
- AFF A400
- FAS8700
- FAS8300
- 予期しないテイクオーバー(ハートビートアラートなし)
問題
- ノードの予期しないテイクオーバー:
[node_name_1: cf_main: cf.fsm.takeover.noHeartbeat:alert]: Failover monitor: Takeover initiated after no heartbeat was detected from the partner node.
- レポートされるハートビートメッセージ:
[node_name_1: cf_main: fm_lastHeartbeatInfo_1:debug]: params: {'time_since_firmware_rcvd': '5000', 'time_since_htbt_read_attempt_ic': '1000', 'time_since_mb_upd_minor_seq': '13', 'time_since_mb_upd_major_seq': '520405022', 'time_since_htbt_read_success_ic': '6000', 'current_time': '520650179', 'time_since_htbt_read_success_mb': '4029', 'time_since_ic_upd_major_seq': '520407022', 'time_since_htbt_write_ic': '0', 'time_since_first_htbt_write_mb_drop': '259840013', 'time_since_htbt_write_mb': '13', 'time_since_ic_upd_minor_seq': '0', 'mb_htbt_drop_count': '10', 'time_since_recent_htbt_write_mb_drop': '259837513', 'time_since_firmware_written': '0', 'time_since_htbt_read_upd_seq_ic': '6000', 'partner_minor_seq_num_mb': '728568', 'time_since_firmware_read': '6979', 'partner_minor_seq_num_ic': '728567', 'partner_major_seq_num_ic': '1669711236', 'time_since_htbt_read_upd_seq_mb': '4029', 'partner_major_seq_num_mb': '1669711236', 'time_since_htbt_read_attempt_mb': '4029'}
[node_name_1: cf_main: fm_lastHeartbeatInfo_1:debug]: params: {'time_since_firmware_rcvd': '20000', 'time_since_htbt_read_attempt_ic': '1000', 'time_since_mb_upd_minor_seq': '13', 'time_since_mb_upd_major_seq': '520420022', 'time_since_htbt_read_success_ic': '21000', 'current_time': '520665179', 'time_since_htbt_read_success_mb': '867', 'time_since_ic_upd_major_seq': '520422022', 'time_since_htbt_write_ic': '0', 'time_since_first_htbt_write_mb_drop': '259855013', 'time_since_htbt_write_mb': '13', 'time_since_ic_upd_minor_seq': '0', 'mb_htbt_drop_count': '10', 'time_since_recent_htbt_write_mb_drop': '259852513', 'time_since_firmware_written': '0', 'time_since_htbt_read_upd_seq_ic': '21000', 'partner_minor_seq_num_mb': '728568', 'time_since_firmware_read': '21979', 'partner_minor_seq_num_ic': '728567', 'partner_major_seq_num_ic': '1669711236', 'time_since_htbt_read_upd_seq_mb': '19029', 'partner_major_seq_num_mb': '1669711236', 'time_since_htbt_read_attempt_mb': '867'}
- パニックメッセージが見つかりません。
- 場合によっては、SSRAMログが入力されることがあります。
SRAM record type(CPU) from Data ONTAP: socket(0) core(8) bank(6)
SRAM record type(LOG) from Data ONTAP: IIO MCE Root Bus(23), Device(0), Function(0), Segment(0).
- ノードのリブートによってギブバックが完了し、正常な動作が続行されます。
- 同じシグネチャで複数の再起動が発生する可能性があります。
