メインコンテンツまでスキップ
Coming soon...New Support-Specific categorization of Knowledge Articles in the NetApp Knowledge Base site to improve navigation, searchability and your self-service journey.
e0M がトラフィックを正常に転送している間、 BMC はネットワークトラフィックを転送しません
65
Visibility:
Votes:
0
Category:
aff-series
Specialty:
hw
Last Updated:
環境
  • AFF-A800
  • ONTAP 9
  • BMC
問題
  • AFF-A800 の BMC は e0M でトラフィックを転送しません( SP / BMC に接続)。
  • ONTAP は e0M (ノード管理 LIF に接続)を介して問題なしでトラフィックを転送します
  • ONTAP は BMC をオンラインと報告します
 ::> net port show (network port show) Node: clusterA-01 Speed(Mbps) Health Port IPspace Broadcast Domain Link MTU Admin/Oper Status --------- ------------ ---------------- ---- ---- ----------- -------- e0M Default bd_mgmt up 1500 auto/1000 healthy
  • Sysconfig -a ただし、イーサネットリンクはと報告さ 'Down'れます。
 Service Processor Status: Online Firmware Version: 10.4 Mgmt MAC Address: 00:a0:98:f1:19:2e Ethernet Link: down Using DHCP: no IPv4 configuration: IP Address: 10.9.51.230 Netmask: 255.255.255.0 Gateway: 10.9.51.1 IPv6 configuration: Disabled
  • また、次のようなシステムヘルスアラートが表示される場合があります
 ::> system health alert show Node: clusterA-01 Resource: SP Config Severity: Major Indication Time: Thu Jun 25 14:12:35 2020 Suppress: false Acknowledge: false Probable Cause: Service Processor in node clusterA-01 has no network connectivity. The cable between the Wrench port on the controller and the ethernet switch is disconnected. Possible Effect: You might not be able to use the Service Processor to remotely access, monitor, and troubleshoot your storage system. Corrective Actions: 1. Check the connection between the Wrench port and the ethernet switch. 2. If the cable is properly connected, ensure that the Service Processor's ethernet interface is configured properly by executing the command "system service-processor network show". 3. Check for network cable related issues. 4. Contact the technical support if the alert persists.
New to NetApp?
Scan to view the article on your device
