ONTAP で AFF A700 または FAS9000 システムのセンサーエラーが複数報告されることがあります
環境
- ONTAP 9
- AFF A700
- FAS9000
- AFF A900 の略
- FAS9500
問題
ONTAP は、 AFF A700 システムで複数のセンサーエラーを報告し、自動的に回復します。
例:
Thu Apr 30 00:27:48 UTC [node: env_mgr: monitor.ioCard.degraded:alert]: IO card is degraded: IO9 SAS Inflow Temp is not readable
Thu Apr 30 00:27:48 UTC [node: env_mgr: monitor.ioCard.degraded:alert]: IO card is degraded: IO9 SAS Outflow Temp is not readable
Thu Apr 30 00:27:48 UTC [node: env_mgr: monitor.ioCard.degraded:alert]: IO card is degraded: IO9 SAS ASIC DieTemp is not readable
Thu Apr 30 00:27:48 UTC [node: env_mgr: monitor.ioCard.degraded:alert]: IO card is degraded: IO9 SAS P3.3V is not readable
Thu Apr 30 00:27:58 UTC [node: env_mgr: monitor.ioCard.degraded:alert]: IO card is degraded: IO9 SAS P1.8V is not readable
Thu Apr 30 00:27:58 UTC [node: env_mgr: monitor.ioCard.degraded:alert]: IO card is degraded: IO9 SAS P1.0V is not readable
Thu Apr 30 00:27:58 UTC [node: env_mgr: monitor.ioCard.degraded:alert]: IO card is degraded: IO9 SAS P0.9V is not readable
Thu Apr 30 00:27:58 UTC [node: env_mgr: monitor.ioCard.degraded:alert]: IO card is degraded: IO9 SAS 5V Standby is not readable
Thu Apr 30 00:27:58 UTC [node: env_mgr: monitor.ioCard.degraded:alert]: IO card is degraded: IO9 SAS P12V HS is not readable
Thu Apr 30 00:27:59 UTC [node: env_mgr: monitor.ioCard.degraded:alert]: IO card is degraded: IO9 SAS Hot Swap Cur is not readable
Thu Apr 30 00:28:00 UTC [node: monitor: monitor.globalStatus.critical:EMERGENCY]: Chassis temperature is too high.
Thu Apr 30 00:28:43 UTC [node: env_mgr: monitor.chassisTemperature.ok:notice]: Chassis temperature is ok.
Thu Apr 30 00:28:43 UTC [node: env_mgr: monitor.ioCard.ok:notice]: IO card on slot 9 is OK
Thu Apr 30 00:29:00 UTC [node: monitor: monitor.globalStatus.ok:notice]: The system's global status is normal.
