NDVIMM の交換後に NVMEM サブシステムの初期化に失敗したか、設定チェックがパニック状態になったため、システムがシャットダウンします
環境
- AFF A800
- NVDIMM
- ONTAP 9
問題
NVDIMM の交換後、 30 分タイムアウト後にシステムがパニック状態になります。
/etc/netapp_loadnvram: 1: not found
Loading NVDIMM1 firmware version 2.6.2.c (was 2.5.2.c)
Programming NVDIMM1 FW. This could take over 8 minutes. Please wait...
..................................................................................Tue May 4 15:53:54 2021 [nvdimm.fw.upgrade.succeed:NOTICE]:NVDIMM controller firmware in slot-23 was upgraded to 2.6.2.c.
.........[nvdimm.nvmem.initfail:FAULT]:NVDIMM startup failed due to FW upgrade timeout. To prevent NVMEM data loss, halt the system.
NVMEM subsystem failed initialization or configuration check
Set bootarg.init.battery_override can ignore this error and continue to boot.
PANIC : System is going to shutdown because NVMEM subsystem failed initialization or configuration check.
Dumper is not yet registered. A coredump will not be available at this time.
System halting...
